The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Panda (Classic)
Old 20-08-2007   #1
taffy git
gaz.d's Avatar
Trader Rating: (2)
gaz.d has donated! United Kingdom
blown radio fuse
I tried putting in a new headunit this morning. It didn't go to plan
Headunit and clock doesn't work. Looked for the blown fuse but I not sure which one it is. I assumed it was service but it not a see through fuse so couldn't tell if it broke
Please help I wanna fit my tv
Gaz
Marea Weekend
gaz.d is offline
Old 20-08-2007   #2
Bandido A Maneira!!
bandido41's Avatar
Trader Rating: (1)
bandido41 has donated! South Africa
Re: blown radio fuse
Check all the fuses?
All the arms we need are for hugging!
bandido41 is offline
Old 20-08-2007   #3
taffy git
gaz.d's Avatar
Trader Rating: (2)
That take time and most of them ain't see through
Gaz
Marea Weekend
gaz.d is offline
Old 20-08-2007   #4
Bandido A Maneira!!
bandido41's Avatar
Trader Rating: (1)
Pull them out it shouldnt take to long how many fuses can the old panda have?
Old 20-08-2007   #5
taffy git
gaz.d's Avatar
Trader Rating: (2)
Got to be about 20, how can I tell if they blown without looking through them
Gaz
Marea Weekend
gaz.d is offline
Old 20-08-2007   #6
Bandido A Maneira!!
bandido41's Avatar
Trader Rating: (1)
The non see through ones have got a slit in the side which allows you to see the wire if its broken or not, ( i am assuming you got blade fuses and not the old porcelain ones? ?)
Old 20-08-2007   #7
taffy git
gaz.d's Avatar
Trader Rating: (2)
I assume they blade too. Don't know what porcelain ones are
Gaz
Marea Weekend
gaz.d is offline
Old 20-08-2007   #8
Bandido A Maneira!!
bandido41's Avatar
Trader Rating: (1)
the old tube style fuseslike in the old escorts and them older cars.
Old 20-08-2007   #9
taffy git
gaz.d's Avatar
Trader Rating: (2)
Nah they blade. Panda only 16 y.o
Gaz
Marea Weekend
gaz.d is offline
Old 20-08-2007   #10
Bandido A Maneira!!
bandido41's Avatar
Trader Rating: (1)
You could also just buy a set of new fuses and replace them all (the non see through ones at least) then next time you will be able to see if they blown or not
(T) Reasons for blown fuse 4paws Uno 2 27-02-2007 06:21
(T) blown fuse popozuda52 Bravo / Brava 5 09-06-2006 19:14
Die Hard!!! The Negotiator Leisure Lounge 27 24-04-2006 22:20
(G) fiat uno 45s radio fuse help Angeloutkast Uno 13 10-07-2005 09:40
(T) Blown Indicator Fuse klaus23 Punto 1 30-04-2004 01:37
