Posts: 17 Thanks: 0 Trader Rating: 0 | fiat 128 engine swap
| Join Date: Mar 2004 Location: harrogate, United Kingdom.
Posts: 151 Thanks: 0 Trader Rating: 0 | Re: fiat 128 engine swap I have done this conversion to 2 of my previous 128 coupes. If you can find a 1500 engine used in the fiat strada or ritmo, all you would need to do is fit your 128 engine mounts, and it will bolt straight into your 128 engine bay. You could also use the x1/9 engine, which is the same engine, but has a different sump and oil pick-up. I understand that this is because the engine leans at an angle in the x1/9 bay, so would recommend using the strada type sump and oil pick-up to ensure no oil starvation! Note-the 128 oil pump and pick-up is apparantly different, so I suggest you don't swap them over! I fitted electronic ignition from the uno 1300, and fitted a fast road cam and weber 34dmtr carb, and it went like the wind! I also tried twin weber carbs, but found that the car lost all driveability for everyday driving, being either stop/or flat out, which is no fun. You could even use the lancia delta 1500 sohc, as it is also the same engine, again, utilising the 128 mounts. You may want to use the 5 speed gearbox from the strada/ritmo/delta, as the 128 4 speed is too low geared really. The gearbox bolts straight in, with very minor mods to drive shaft ends. 128 gear linkage can be used, but you will have to 'press down' to change from 4th to 5th, which is a bit quirky but still worthwhile imo.
| | #3 | ||
Posts: 51 Thanks: 1 Trader Rating: 0 | hi, think on lancia delta engine 1500 with its gearbox, just go ahead!!! In my country (Croatia), that procedure is quite common for all guys who have fiat 128, zastava 101, yugo 45/55/60, because engine fits as original one, no adjustment to make under the bonnet, except to new exhaust system. 115BHP in small car is very hot. . . . Guys with BMW 3 series will have difficulties with you.
__________________ | ||
| | #4 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 | Re: fiat 128 engine swap
| | #5 | ||
Posts: 151 Thanks: 0 Trader Rating: 0 | Re: fiat 128 engine swap-Turbo engine This has also been done already in the Uk by 1 or two people, albeit the uno turbo variant 1301 and 1372 version. Yes it can be done but there is a fair amount of work with wiring harness etc. The engine itself will bolt in utilising the 128 mounts. I'm not sure whether the 128 gearbox was retained or not in those cases, but if it is used, it would need strengthening internally to take all the extra torque. I believe some of the uno turbo internals can be used inside the 128 casing, otherwise special drive shafts in order to use the turbo gearbox. Hope this helps. If you are not needing too much power, I would stick with the 1500cc engine which is a very easy fitment though.
| | #6 | |||||
Posts: 6 Thanks: 0 Trader Rating: 0 | Re: fiat 128 engine swap-Turbo engine
not like 105hp from uno or 130 from punto gt ....i will not do that swapping for only 75 hp only that how could i know the diffrent bettwen the uno engine without turbo and the uno engine with turbo???the same for punto and punto gt with turbo.... i mean there are aturbo inside engine or it is like any normal turbo outside? i hope you understand my qustion
| | #7 | ||
Posts: 151 Thanks: 0 Trader Rating: 0 | Re: fiat 128 engine swap Believe me, if you fit a 1500cc engine, you will notice a big power difference. This engine fitted with only a Weber 34dmtr carb gives 85 bhp, which was standard on the super strada 85. It isnt all about bhp either, you will have a considerable gain in torque. If you then fit a hotter camshaft, you will be quickly up to 95-97 bhp. These mods are both cheap and easy to carry out, as opposed to the turbo conversion. A turbocharged engine will have a plenum chamber, turbo fitted to the manifold etc. The non turbo engines came with both single point injection and multi point injection, depending on the model concerned ie, the uno 1.4 70sx had multi point, whereas the uno start 1.4 came with single point as far as I remember. (in UK anyway) My 1500cc engine pushes out 173bhp in race spec, so don't underestimate this engine
| | #8 | ||
Posts: 14 Thanks: 0 Trader Rating: 0 | Hey im currently trying to put a lancia 2.0l dohc motor in my 128 sl just another option but fitting the 1500 engine is much less work it all depends on how far you want to go i guess. Happy Fiating
| | #9 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 | Re: fiat 128 engine swap How about fitting the 2000cc DOHC from the Ritmo/ Strada 130TC Abarth with its gearbox? whats the work needed in the engine bay?
| | #10 | ||
Posts: 13 Thanks: 0 Trader Rating: 0 | Re: fiat 128 engine swap Im going for a 182.a4.000 1.6 16valve brava motor and box in my 128 sl. Im looking at dry sumping and turboing it to. Should make it quite entertaining.
| | #11 | ||
Posts: 4 Thanks: 0 Trader Rating: 0 | Re: fiat 128 engine swap Hi! Im from Guatemala I have an engine 128A, where i can get an Fiat/Lancia SOHC 1.6..? Here in Guatemala it doesnt exist that engine.. Good Luck with your swap! Regards!
| | #12 | ||
Posts: 630 Thanks: 18 Trader Rating: 0 | Re: fiat 128 engine swap Am I right in thinking the 1500 X1/9 lump is the same as the Strada/Regata/Delta/Prisma 1500 & 1600 lumps? Wouldnt the Tipo/Tempra/Dedra 1600 engine be a straightish swap as well? I get confused with the SOHC engines..
__________________ Currently got.. 89 Panda 750L, 90 Uno 60S, 93 Tempra 2.0ie SW, Jaguar XJR V8, a Porsche Boxster, 2x Daimler XJ40`s, 96 Punto 1.6 Sporting (breaking). The Uno is the most fun! | ||
| | #13 | ||
Posts: 13 Thanks: 0 Trader Rating: 0 | Re: fiat 128 engine swap The brava/marea 1.6 is essentially a sohc unit but with the tohc head and more valves. They had to change some of the oil passages about in the block so you cant bolt the head onto an earlier block. Best thing about them though is anything that had the sohc motor can have the 1.6 put into it with no problems, mounts everything are a swap over job. For what i can gather the sohc engines are all very similar, even the later dedra 1.6's. Theres alot of guys on turbo124 site that have all different incarnations in x1/9's and 128's etc. I know a guy in christchurch NZ that has a 128sl to with an uno turbo motor in it but its had the turbo removed and a toyota supercharger put on to it, runs different injection setup and computer and puts down 160 bhp to the wheels. Tidy beast to.
| Fiat 900e Camper van --I need a new engine | ifisher | Bodyshop | 12 | 23-04-2008 10:51 |
| | ahmed_mahdy2003 | Other Fiats | 1 | 20-10-2006 00:23 |
| Engine swap question | skarbanan | Panda (Classic) | 18 | 30-01-2006 09:37 |
| | ivantate | Cinquecento / Seicento | 19 | 25-01-2006 19:00 |
