Had a problem with car taking several turns of the key at about 15 seconds a time. Decided to take off starter motor, and inlet manifold. Manifold was all messy. Cleaned it out, put back on, put a new starter motor on it and all I’m getting is a click from the fuse in the fuse box under bonnet. Battery is healthy I’ve checked that even used the battery out my 1.9 punto and makes no difference. I’ve cleaned all earth terminals checked for them being frayed or split. Assembled the silly plastic thing they use for the power on the starter and still just a click in the fuse box. Lights do not dim when I try start car. Fuel pump is working ok.
I’m going crazy. I’ve searched for help, and done everything that’s been found and still nothing.
Any help would be great
