General Engine management light
eddy1988
My engine management light came on this morning. Took car to local garage who plugged it into a diagnostics machine. Came back with error code 14H/321 (an undocumented error). Does anyone have any idea what this code means. Thanks
what FIAT, ?
and what did they use to get that code.. it sounds WRONG.. :eek:
google only finds your post..:rolleyes:
charlie - Oxford
It's a grande punto (2007). They used a snap on reader plugged into the right hand side of the steering wheel. All I've read on google is saying that they are codes that can only be read by Fiat.
Thanks Ross
Thanks Ross
Hi Ross, :)
have a look in the GP section ,
there are Engine codes,
then CANBUS - vehicle wiring codes
we've got kit that can read all of that..;)
what exactly were you trying to get sorted..?? :confused:
a common one , is after a poorly executed cambelt change,
Charlie
The engine management light came on randomly this morning. The car was serviced a few weeks ago and they broke an injector. I don't know whether that would have any effect?
Was hoping that the error code would be a simple one (such as an o2 sensor). But now the light is on and local garage can't tell me what the code means.
petrol or diesel.. where are you based..??
charlie
It's petrol. South Wales. I have had the car read again today by a different garage - same error code. They turned the light off, it stayed off. The car was switched off and back on - no light. Then later today when the car was started, the light was back.
Ross
I live in Abertillery. It would be great if you could read it if you are in the area. We are stuck at the moment so have run out of options aside from a main dealer.
Thank you
Ross
there is a potential issue with the vehicles wiring / connections,
( hence the error / warning light?)
I regularly travel over your way ( abertillery / pontypool), so I could bring my MES over if required, should have as good a chance as any..,
Charlie
Hi Charlie,
I ordered the lead off eBay and bought the multiecuscan for my laptop. Plugged it in and was given a P code straight away. Points towards the oxygen sensor!
Thanks for your help
Ross
