850 Fiat 850 Sedan
If owning a Fiat 500F and Fiat 1500 wasn't enough (not to mention the Austin 7)
I decided that I should breathe life back into an 850 sedan that had been resting since the 1980s.
Having lived it's life in Canberra and surrounds it has a very good body.
Here are some pics
great job keep it up, I like those vintage little Fiats, are you going to rebuild/overhaul the original engine or will get a new fitting engine ?
The engine is a rebuilt 903 that I got earlier this year. The engine that was in this car was not original.
I have been making progress with my 500 bambino so the 850 is resting at the moment but I have collected a few parts like brake cylinders etc when I had the opportunity.
Geoff
Wiped the dust off the other day. I have been working on my 500F and pushed the 850 out of the garage so I could paint the 500.
Five and a half years go by and in the meantime the engine seized with varnish from bad old petrol.
About 2 years ago I pulled it all apart, cleaned it up and gave it some new rings.
Since then I have removed the rusted out fuel tank and found a replacement through a fellow Fiat club member, which was lucky.
I picked up another Austin seven recently so the 850 moved to our carport which gives me better access to do some work on it….
