Help - anyone got any series 2 127 wheel nuts going spare or know if wheel nuts from any other Fiats will fit? I need 5 as some of the threads have worn to nothing on mine. Cheers.
Yes most Fiat bolts would fit - just check the length of the thread is the same. Panda, Uno, 128, Cinq, etc are likely to be the same. I usually just fling them on - if they're too short it's obvious as they don't tighten enough, and too long makes a pinging noise when you move the car - most are completely interchangeable from steel wheels (alloys usually need longer bolts).
Loads on Ebay - just get the right size and away you go.
