Posts: 1 Thanks: 0 Trader Rating: 0 | fiat 850 - Lowering Front Suspension? Hooray! First Fiat 850 post! To get things started, I would like to know how to safely lower the front suspension of my 850 coupe by 1 to 1 1/2 inches. Looking at the front end, it looks like the car could be lowered by reversing the main leaf of the front spring so that the eyes at the end of the spring are higher, thus raising the stub axle (and lowering the car). It looks like this would lower the car by 3-4 cm, which is probably enough. Has anyone tried this? Does it work? Or does anyone know of a reason not to do this - does it cause alignment problems, am I risking damaging something?
Posts: 5 Thanks: 0 Trader Rating: 0 | Re: fiat 850 - Lowering Front Suspension? My first car was a series 1 850 coupe. I did infact flip just the lower leaf spring over to lower the car. I did like the look. but it was a hard ride. and after several years the "bridge" that holds the spring into the car began to buckel. (But to be fair I was 16 and VERY Hard on the car) I just completed re-lowering my current 850 spider. This car was lowered using the much better method of lowering the leaf bolt holes in the knuckle. However the camber angle was changed (for racing) and it was too agressive for the street. Now Im low with correct camber. Re-aligning is necessary with either change. Dale
| | #3 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 | Re: fiat 850 - Lowering Front Suspension? best way to lower front suspention is to bash the leafspring I used to do that on my racing zastava 750 , with 1050 engine.Normal fica leafspring is 27cm , i lower it on 12cm and it was flat , i put 12inch rims , ET was -10 , but for 13 inch rims , 16-18 is best with no problems.Just take your leafspring to blacksmith and tell him to lower it to height as you want.
| | #4 | ||
Posts: 2 Thanks: 0 Trader Rating: 0 | Re: fiat 850 - Lowering Front Suspension? Or you can contact me direct.I bought 12 fiat 850 in 1 day and have owned over 30 850s.I competed for 14 years in an Abarth tuned version.Until recently i had an OT 1300/124 Abarth version and i still race an OTS Abarth version.Both have been fitted with lowering blocks that keep full travel and permit camber adjustment.The ultimate bolt on bolt off solution.it worked perfectly on my car in Targa Tas. grant_gauld@yahoo.com.au
| | #5 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 | Re: fiat 850 - Lowering Front Suspension? There are out there kits that I have seen that do a coil-over conversion. This is done by an aluminium cross memeber bolted to the front chassis, replacing the leaf spring and coiled shocks are then put in place to provided the dampening. I have seen cars (albeit in the US) lowered by 1 1/2"-2" with adjustable camber angles.
| | #6 | ||
Posts: 19 Thanks: 0 Trader Rating: 0 | Re: fiat 850 - Lowering Front Suspension? hi guys, ive looked at the various ways of lowering the front, i think id like to go with the 1960's abarth approach using the straight as opposed to curved front cross member, before i send mine for surgery, does anyone have the dimensions or drawings to make a replica abarth one? ....i know there availible from FAZA in the USA but post and import duties here make a locally made unit preferable. i intend to use the shorter rear shocks up front to match the lowered spring mount...any input on my ideas?
| | #7 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 | hey 126dave. did you get the front lowered on your 850? if so what did you end up doing?
| | #8 | ||
Posts: 1 Thanks: 0 Trader Rating: 0 | Re: fiat 850 - Lowering Front Suspension? I was wondering the same thing i have a 850 sedan i want to lower in the front i already moved the leaf mounting point to the spindle about a inch lower. Is there any other way to get a 1" or 1.5". Without spending a ton of money on cross members and coil overs.
| | #9 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 | Re: fiat 850 - Lowering Front Suspension? bmw flying. yeh i've seen the independant front end advertised. not cheap! add on frieght and it's over the top!
| | #10 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 | Re: fiat 850 - Lowering Front Suspension? When I first lowered my 850 sedan I installed the lowering spring perch and reversed the eyes on the spring and that brought it down almost 3 inches in total. It looked like this ![]() I then made drop spindles by welding extension tabs to the kingpin housing for 2 and half inches of drop and used a stock spring with the lowering perch ![]() And it looks like this
| | #11 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 | hey ditchdigger. your 850 looks sweet as. nice ride hight. how did you determin the offset for the new spring bolt hole? (it is not in line with the old spring bolt hole and the top spindle mount hole). also while i'm at it, do you have the sizes (dimensions) of your lowered spring perch. thanks for all / any help.
| | #12 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 | Re: fiat 850 - Lowering Front Suspension? The lowering block is the Faza unit If it had not been included with the purchase of the car I would not have bought one. It is so simple as to be laughable. All it is is a piece of steel formed channel with 9 holes drilled into it. Were I to make my own I would probably use aluminum channel. The offset for the bolt hole was approximated from pictures of 70's race cars and from what John Edwards did to his 850. It turned out to be far too much offset and I had over 5 degrees negative camber. I had to shim the upper control arm .25 inches to bring the camber back down to 2 degrees which is still too much and now my front track is so wide that the tyres rub the arches. I will redo the extensions soon and bring that hole closer to the factory location....just down a bit
| | #13 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 | Re: fiat 850 - Lowering Front Suspension? ok thanks for that info. i will start on the lowering block first then atack the axle extensions. thanks again.
| | #14 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 | Re: fiat 850 - Lowering Front Suspension? Here are some pics of an aluminum lowering block that I found a while back ![]() ![]()
| | #15 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 | Re: fiat 850 - Lowering Front Suspension? OK now that I have 5 posts I can now post links I followed this to reverse the spring eyes. http://www.jalopyjournal.com/forum/s...wn+spring+eyes
| | Body Stylist | Punto | 30 | 09-04-2005 16:02 |
| MODELS FIAT SHOULD MAKE! | jetweed | Lets Talk FIAT | 61 | 30-08-2004 20:38 |
| | sonia cachia | Bravo / Brava | 7 | 20-10-2003 03:30 |
| | arseofbox | Cinquecento / Seicento | 3 | 17-07-2003 23:11 |
| | christos | Stilo | 5 | 25-06-2003 21:22 |
