Thread Tools
Old 03-01-2017   #1
peugeot speedfight 3 moped won't run
Hello everyone, I am having some trouble with the bike I use to get to work. it is the 50cc air cooled model and is 3 years old.
it starts fine (both kick start and electric) but as soon as you touch the throttle it dies. it has been stood still for nearly 4 weeks now but when I bought it in october the previous owner said it had been unused for 3 months.
I have changed the spark plug and battery.
thanks
Heather
WolfCrazy64 is offline Reply With Quote Quote
Old 03-01-2017   #2
varesecrazy has donated!
Re: peugeot speedfight 3 moped won't run
Hi. One of 2 things..
Either fuelling. Or igntion..
So..it starts well.
Start it and let it idle for 2 minutes
Then try the throttle..
I suspect youve got a bit of water(from condensation) in the carb/ injector body
If it will idle for 5 mins..but still dies at throttle..let us know..
Charlie
Old 03-01-2017   #3
Good luck..!!
Old 04-01-2017   #4
Nigel
portland_bill's Avatar
Trader Rating: 1
portland_bill has donated!
Is it carb or injection?
If carb, the slide is probably stuck, so when the throttle is opened it does not lift, so the air/fuel mix is wrong.
It probably has a diaphragm above the slide, this may be split.
13 years motor trade, 16 years motor industry. 13 years Driving Instructor & 6 years Fleet Trainer
Panda Alessi
portland_bill is online now Reply With Quote Quote
Old 04-01-2017   #5
hello it is a carb one, and although the bike starts it cuts out after about 10 seconds.
also the battery looks like it is going flat again
Old 04-01-2017   #6
Quote Originally Posted by WolfCrazy64 View Post
Hi. Auto choke too I Suspect.
Id attempt to drain a little fuel..there would normally be a small bleed screw at bottom of carb.
Obviously its petrol ..so a well ventilated area..and no smoking
Charlie
Thread Tools
(T) Won't run and has no spark KarenLeo Cinquecento / Seicento 28 19-10-2011 10:24
(T) Cinquecento won't run! jerryclelford Cinquecento / Seicento 11 13-12-2008 23:35
(T) X1/9 won't start or run hermes von xist X1/9 1 30-07-2007 11:31
