FIAT Auto Specialist Team
Thread Tools
Old 26-11-2016   #1
How do you drive a dualogic?
This may sound like a reeeeally stupid question.. but.. How do you drive a dualogic? I've always drove a manual but a car i've got my eye on is a dualogic. I know it doesnt come with a clutch so how would you not roll backwards on a hill etc?
Are they any good? This is a 1.2 if that makes any difference
Thanks!
Susielou is offline Reply With Quote Quote
Old 26-11-2016   #2
varesecrazy has donated!
Re: How do you drive a dualogic?
Quote Originally Posted by Susielou View Post
Thanks!
they basically depress their own clutch as you stop.. so it'll roll just like any manual..
it's a balance of revs and handbrake like any other car.. but without the worry of the clutch pedal too
they are o.k. to drive.. but DO have added complexity ., so I'd rather buy a manual unless you NEED to go clutch free
over say 100 ,000 miles it'll need more servicing time..
BUT if you are hopeless with clutch control you could save @2000 in the clutches you've not ruined..
( My late Grandads record was 260 miles on a clutch kit ( FIAT 124 )
Charlie
Old 27-11-2016   #3
Hi' A working Dualogic is a dream to drive. It's like an automatic without 'creep' , and you can over-ride it ,to change up or down a gear when it's in 'auto' . Mind you; it changes back after 10 or so seconds if it thinks you've got it wrong. You can also use it as a clutchless manual , and there again, if it thinks you've got it wrong it will over-ride you. I've been driving them for 12 years now so have had good and bad ones. When they are good they are really good , but get a bad one and they are terrible... and expensive , and nobody in the Fiat network seems to know how they work. They drop the engine revs when they change up and rev up when they change down . Magic.
BUT if you are buying second hand be very aware. They can be very expensive to fix , as garages will only change components , i.e. HP pump and reservoir, or whole actuator or ECU. Make sure you have a cast iron warranty, and look through the Forum to see the trouble that owners have before commiting. I suppose that basically you have to balance how good they can be against what they might cost if problematic.
DavyP is offline Reply With Quote Quote
Thread Tools
(G) Mini Cooper to 500 1.2 Lounge Dualogic/0.9 Twin Air dualogic - Finance question Mini2500 500 15 20-05-2012 22:53
(T) How does Dualogic work/drive? Alxandr Grande Punto 1 16-04-2011 17:17
(T) Panda Dualogic no drive jimbo1970 Panda 15 09-03-2011 12:21
(G) MK 2.5 1.2 Dualogic drive by wire. adam123 Punto (Mk2/2b) 2 06-10-2006 14:28
512MB Flash Drive/USB Key or Pen Drive Liam Leisure Lounge 4 02-09-2005 09:22
