Lamps by Post - For all your lighting needs
Thread Tools
Old 03-03-2016   #1
FerrariInAffordableTrim
bravo86gaz has donated!
Honda Jazz noise ???
Ok so Mrs Bravo has a 57 Honda Jazz 1.4 (working on bringing her to the dark side with a 500) that has a rubbing noise from the right wheel when turning right, gets faster as speed increases but not louder & the tyre is worn on inside edge,
Had 2 new wishbones & brakes as part of mot last year that are all working as they should
I've jacked up and had a nose but the noise isn't present when suspension is uncompressed, there's no play in the wheel or suspension, could it be wheel bearing or driveshaft/CV on their way out??
bravo86gaz is offline Reply With Quote Quote
Old 03-03-2016   #2
varesecrazy has donated!
Re: Honda Jazz noise ???
Quote Originally Posted by bravo86gaz View Post
COULD BE..,
in this situation I've removed front roadwheels,
put axle stands under front structure - to support body
then run in 2nd gear , the 2 x front driveshafts will "idle" ,
you have the option of going up through the gears ..
0 -100 on 0.5 seconds
and even swinging steering lock to lock at any speed. as there is NOTHING in contact with "the road",
I actually found the noise was amplified by vibration, and was more noticeable in the cabin than stood by the hub..
you "could" put a jack under the wishbone to raise the CV , and put SOME load on the suspension also..,
but I'd do it "free" 1st,
let us know what you find,
Charlie
Old 03-03-2016   #3
Decided to put it into garage, at 170 for a non genuine shaft (800 for oem) before fitting it's not something I want/can afford to be wrong with
Like the idea of that 0-100 though, quickest the little things ever been
Old 17-03-2016   #4
Well after a trip to kwik fit *shudder* and a pair of paddy macguires, the back plate was catching slightly on brake disc, and also sticky top mounts
Old 29-10-2016   #5
Hong Kong
I also have HONDA JAZZ before,
but I change Freed now....
seems better
mrstsang is offline Reply With Quote Quote
Thread Tools
Honda Jazz Most Easterly Pandas Non-FIAT 5 30-03-2015 17:43
Qubo Mr 2012 Cool Jazz Blue Qubo Mylife!!! philnicandamy Members Motors 8 13-08-2013 07:32
(S) Different ways to jazz it up :) Barbie 500 20 17-07-2013 09:32
(G) Idea v Jazz v Roomster? Jackie Treehorn Idea 4 16-03-2011 09:06
honda jazz 2009 jug Non-FIAT 8 31-10-2008 21:46
