Thread Tools
Old 26-04-2011   #1
x Alex x has donated!
measuring DC milliamps draw
hey all, trying to work out the draw of something, can't find much on the 'net about it.
read up on the 'net about disconnecting the neg battery lead, and letting the current flow through the multi meter in the neg post on the battery?
wanted to double check before i blew my multi meter up
cheers, Alex
Grande Punto 1.9 Multijet Sporting
x Alex x is offline Reply With Quote Quote
Old 26-04-2011   #2
Re: measuring DC milliamps draw
for amps it does need to be in line yes. if your only working out milliamps then you should be fine otherwise most only go up to 10a which is not enough for a car
Thanks x Alex x thanked for this post
the invader: http://www.fiatforum.com/members-motors-non-fiat/270284-its-ford.html#post2762950
Quote Originally Posted by The Unknown View Post
IV Seen Bigger
Come to the darkside. We have cookies !
dronenrs is offline Reply With Quote Quote
Old 26-04-2011   #3
Quote Originally Posted by dronenrs View Post
great, do i need the dial on A- 2000u?
cheers for the reply!
Old 26-04-2011   #4
what amperage you looking at getting or is the the only milli setting if theres other settings flick through till you get a reading you can understand
IV Seen Bigger
Old 26-04-2011   #5
not sure, it's just a little blue led display on a 12v system, ill go out and try before it gets too dark
thanks again
Old 26-04-2011   #6
i got around 46 when the dial was on DC 20M
Old 26-04-2011   #7
cool thats 46 milliamps then
IV Seen Bigger
Old 26-04-2011   #8
does that sound about right for this?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=270719883914
thanks again for the help mate
Old 26-04-2011   #9
well being LCD that will draw a pretty tiny current. probably draw about as much as the clock would so yeah sounds about right
IV Seen Bigger
Thread Tools
Earthquake measuring 3.6 on the Richter scale has hit Cumbria Shadeyman Leisure Lounge 5 23-12-2010 13:45
Measuring Valve Tappet Adjustment kkemerait Lets Talk FIAT 16 19-07-2010 17:13
Ecodrive - what's it measuring? colin79666 Blue and Me 7 12-06-2009 22:28
Looking for Someone Who Can Draw darkcircuitUK Leisure Lounge 15 12-07-2005 22:04
(T) gauge of sumsort for measuring air going thru the induction kit imola_fowkes Cinquecento / Seicento 3 10-09-2004 00:10
