| Get a wriggle on! | invertor question heres one for you all. those invertors that take your cars 12v supply, and make it into a 240v socket, to power stuff with. if you plugged the invertor in, then attach a 12v battery charger to it, and then connect the charger leads to the battery, will it charge the car battery?? hmm | ||
| blessed are the apostates | Re: invertor question no, it will discharge the battery. | ||
| | #3 | ||
| Shropshire UK | Re: invertor question Ideally with an Inverter you should use a dual battery system so you dont drain down the battery for the car, this requires some wiring for a split charging system. Well documented in Caravan Club books and the such I think.
__________________ Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque. | ||
| | #4 | |||||
| | #5 | ||
| A Panda with Gadget's | Re: invertor question Probably wouldn't but just curious like me. For example. Would a car with a wind turbine on it run forever once it got going because car runing turn the fan, fan powers that car, and so on, ever lasting power? Same with a Solar powered light infront of its own solar pannel. Once it's lit will it burn forever?
__________________ Bright in White... Look at those spots and the 240 watt of 4 Halogen bulbs!If my post or someone else's has helped, say thank you using the Thanks Button \/ | ||
| | #6 | |||
| | #7 | ||
| Get a wriggle on! | Re: invertor question | ||
| | #8 | ||
| Gavin | Re: invertor question Levemir and Jon, what you're proposing is the same as "perpetual motion". As none of the devices are 100% efficient then none of the proposed options are possible. Perpetual motion only ever happens in the worlds of Heath Robinson, Roland Emmett and Punch. ![]()
__________________ ![]() | ||
| | #9 | ||
| RA5 4LEX | Re: invertor question theyre very ineficiant. where would the extra electric come from? lol
__________________ 2004 Fiat Punto 1.2 15" Ace 205 Alloys - CD/MP3 Player Sub + Amp - Remote Central Locking And Alarm - Tinted Rear Lights. 1989 Ford Escort RS Turbo Cabroilet, TurboSystems Chip, Phase 1 Turbo, RST Brakes, Electric Mirrors/Windows/Hood. | ||
| Engine Oil question and question about electrics | meg1409 | Punto > Technical | 0 | 12-06-2008 22:58 |
| question about car price question.... | serin | Leisure Lounge | 16 | 31-08-2006 21:52 |
| 300w invertor approx £20 inc. P&P | The Negotiator | Leisure Lounge | 1 | 10-11-2005 01:57 |
| 74 Spider carb question???? and drive shaft question | dicast1969 | Spider | 1 | 16-04-2005 08:19 |
| power invertor | gaz.d | I.C.E | 11 | 21-03-2005 21:03 |
