The FIAT Forum
Go Back   The FIAT Forum > General > Leisure Lounge > Non-FIAT
Old 13-05-2008   #1
RA5 4LEX
Alex-R's Avatar
Trader Rating: (0)
Alex-R has donated! United Kingdom
New Dial cluster not working properly
just fitted the Lockwood dials on the RS that i got with the car.
speedo works fine (checked against the sat nav)
Rev counter is reading roughly 1k under, so ticks over at 0.
fuel guage flutters about, quarter tank shows nearly full.
temp guage starts at a quarter and goes to the red when warmed up.
first time i've done this so i'm not really sure what i can check.
thanks a lot!
2004 Fiat Punto 1.2 15" Ace 205 Alloys - CD/MP3 Player Sub + Amp - Remote Central Locking And Alarm - Tinted Rear Lights.
1989 Ford Escort RS Turbo Cabroilet, TurboSystems Chip, Phase 1 Turbo, RST Brakes, Electric Mirrors/Windows/Hood.
Alex-R is offline
Old 13-05-2008   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
Re: New Dial cluster not working properly
are you saying the tacho, temp and fuel gauge were all ok before you touched it?
jug is offline
Old 13-05-2008   #3
RA5 4LEX
Alex-R's Avatar
Trader Rating: (0)
yeh, fine on the other dials.
Alex-R is offline
Old 13-05-2008   #4
jug
jug's Avatar
Trader Rating: (1)
if you took the needle off the tacho then you've put it back on in the wrong position, wiggl eit till its almost off, then carefully use some small long nose pliers to grip the shaft while you move the nedle to the correct place (1k more than it currently is)
in my experience, the only time the fuel gauge futters on the mk4 is when there is electrical intereference, so tbh i'm not sure what to suggest there but correcting it requires you to grip the shaft when it is at full and move it down to 1/4.
sounds as though the fuel gauge needle needs to be adjusted too. grip shaft when its at 1/4 then move needle down so it sits below the min.
i dont understand why any of this is neccessary, lockwood dials can be fitted without removing the needles.
jug is offline
Old 13-05-2008   #5
RA5 4LEX
Alex-R's Avatar
Trader Rating: (0)
Sorry, i mean the whole cluster was changed, not just the backing, suppose i could sort the rev counter by moving the needle, as for the temp guage, it starts from below where a normal one would and shoots up into the red when warm
Alex-R is offline
Old 13-05-2008   #6
jug
jug's Avatar
Trader Rating: (1)
tut tut so your mileage has changed too!
be a good lad, fit the lockwood dials to your original cluster, its a 10min job and then you can avoid using a cluster that has obviously been attacked by a tard in the past.
jug is offline
Old 13-05-2008   #7
RA5 4LEX
Alex-R's Avatar
Trader Rating: (0)
lol, TBH i wasn't aware they were both orginally standard clocks, obviously the one i've fitted has had the lockwood covers put on.
my plastic covers cracked too so i guess i'll make 1 good set out of 1
Alex-R is offline
Old 13-05-2008   #8
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
AppleSei has donated! United Kingdom
Are these the stick on style of lockwood dials?
If so the glue is really pants on them and the dials can sometimes lift up so they arent sat right, so can cause the needles to catch on them.
Would take it all apart and if they have lifted up just use a prit stick or something simialr to glue it down
See if that makes an improvement
2001 Modded Sei Sporting - GONE!!
1998 Ford Mondeo 1.8LX - P/X'ed
2002 02 Ford Focus 1.6 Zetec w/ Climate Pack!
AppleSei is offline
vB code is On
Punto Lights not working properly Vague Punto > Technical 9 06-11-2007 02:35
Indicators not working properly joey54 Punto > Technical 3 09-04-2007 10:10
MK1 Dial Cluster oldskoolmk1unoturbo Uno > Styling 1 09-11-2006 08:55
power steering not working properly scotty Punto 2 22-02-2005 17:03
Search Engine not working properly steveyensen Leisure Lounge 5 30-06-2003 02:35
