The FIAT Forum
Go Back   The FIAT Forum > General > Leisure Lounge > Non-FIAT
Old 14-04-2008   #1
You can't fool owls.
Hellcat's Avatar
Trader Rating: (3)
Hellcat has donated! United Kingdom
Renault Clios....
are they prone to spontaneous ignition?
One down the road's just gone up in flames... thought it was valdalisim but think the bangs I heard were the tyres popping.
Can only have parked upto at most an hour ago.
'Not everything in black and white makes sense'
Hellcat is offline
Old 14-04-2008   #2
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
Re: Renault Clios....
chavs ice install with no gromet where live feed for amp goes into car?
Binki
dave is offline
Old 14-04-2008   #3
Hellcat's Avatar
Trader Rating: (3)
and what happens? I mean to cause a fire....
Hellcat is offline
Old 14-04-2008   #4
__________
dave's Avatar
Trader Rating: (10)
wire gets cut by body work where it goes through then spark, then BOOM
Binki
dave is offline
Old 14-04-2008   #5
Hellcat's Avatar
Trader Rating: (3)
Isn't there a car that's prone to setting itself on fire as standard? Seem to remember it on watchdog.... sure it was clios.
Hellcat is offline
Old 14-04-2008   #6
__________
dave's Avatar
Trader Rating: (10)
pugs do that
Binki
dave is offline
Old 14-04-2008   #7
BRUM!!
maddogmorg's Avatar
Trader Rating: (0)
maddogmorg has donated! United Kingdom
it was corsas which spontaneously combust, the clios have bonnets which open on the move. my driving instructors clios air con exploded not long before my test apparently. i ended up in a petrol clio instead.
The Artist Formerly known as Besbie.
maddogmorg is offline
Old 15-04-2008   #8
Xen
FFFTW!
Xen's Avatar
Trader Rating: (0)
Xen has donated! United Kingdom
live wire insulation gets damaged by the holes and shorts out against the bodywork. Then either the battery could explode depending on type, or the wire will get hotter and hotter, eventually causing the insulation around it to catch fire, then cause other flammable items close by to catch fire aswell - before you know it, burnt out clio/corsa/saxo.
Similar to this clip. Not really a short, but his wiring is too thin for the current load - same effect as a short - wiring heats up, starts to smoke, insulation catches fire...
If my post has helped you, please click the Thanks button Cheers.
Xen is offline
Old 15-04-2008   #9
Xen
FFFTW!
Xen's Avatar
Trader Rating: (0)
or as this t!t shows by shorting a wire across a Yuasa SLA...
Xen is offline
Old 15-04-2008   #10
ScoobyChris's Avatar
Trader Rating: (0)
IIRC, the Mk1 V6 Clio was prone to spontaneously combusting too, but not sure why.
Chris
Holding up the traffic in a little Italian.........
ScoobyChris is offline
Old 15-04-2008   #11
Falling Into A Trap
Joshua Frost-Lunn's Avatar
Trader Rating: (0)
Joshua Frost-Lunn has donated! United Kingdom
Chris
V6 engine the back, quite a lot of heat, sets fire to interior trim or something with the heat
FIAT STILO..... ABARTH IN DISGUISE
SCORPION BADGES, SKYROOF, 17" ANTHRACITE BLADES, ABARTH SIDE SKIRTS AND SPOILER, BLACK OUT WINDOW BLINDS
PREVIOUS: 54 CORSA 1.3CDTI SXI - WRITE OFF
05 MICRA 1.2 16V SE - IN PURPLE - PART EX
Joshua Frost-Lunn is offline
Old 15-04-2008   #12
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
are you sure it isnt due to vandals with taste?
jug is offline
Old 15-04-2008   #13
Trader Rating: (0)
Bit of Googling points to a "wiring fault" causing it. Quite impressive (if it's not your car )
http://www.dngloz.com/cars/pictures/...io-on-fire.php
Chris
Old 23-04-2008   #14
Panda's with Gadget's
Most Easterly Pandas's Avatar
Trader Rating: (0)
Most Easterly Pandas has donated! United Kingdom
pugs do that
Pug 307's with ignition barrel fault with causes the started motor to constantly run, some Corsa's, And BMW Mini's which have had gear box changes. All on Watchdog. Tis an amazing programme
But to be honest if its French then it deserves to go up in flames
Most Easterly Panda's - Panda'ing in East Anglia
5 Panda's! 1989 F-reg 750L, 1991/1992 (not sure as on a NI plate) Panda 1000CL,
1993 K-reg Selecta (1108cc) x2! 1988 E-reg Sisley 4x4
Originally Posted by Jai View Post
grip the meat, loosen the throat, relax and slide it in
If my post or someone else's has helped, say thank you using the Thanks Button \/
Most Easterly Pandas is offline
Old 23-04-2008   #15
Hellcat's Avatar
Trader Rating: (3)
Don't get me wrong... despite being fire-trained, owning 2 fire extinguishers, and a flame-retardant suit and gloves - I wouldn't have peed on it
Hellcat is offline
vB code is On
Renault Clio Wheels loudpunto Non-FIAT 5 18-03-2008 20:56
FIAT better than Renault and VW dav7nine Lets Talk FIAT 6 23-12-2007 01:46
Renault Laguna angel Non-FIAT 30 03-07-2007 18:29
Renault Megane luvduvs Leisure Lounge 31 10-06-2007 08:44
Renault 5 GT Turbo?? cov69 Cinq/Sei > Technical 46 01-09-2005 19:13
