| 2004 hello everyone,new member here,fantastic site. i own a citroen relay 2004 2.8 hdi sorry to mentoin citroen, b4 i get in a auto electric guy i must ask for your help, i have a fuse that keeps blowing it controls the, (called) the lighting control switch fuse no 31 10 amp,it stops the heater fan and the ciggi lighter and the windscreen washers and wipers from working. i have tried max fuse 30 amp still blows as soon as the ignition is switched on i have spoken to main dealer bring it in and they will put on dio machine , i have removed dash, glove box ,and disconnected each item and tried with new fuse each time and also checked as best i can for any earthing problems with wiring, i just wish to save a few ££££s, hoping for a reply.regards
| Shropshire UK | Re: 2004 Hi and welcome, I have to ask... Have u tried a Citroen Forum at all? My suggestion would be to isolate each item you have listed from its power source and see which item causes the fuse to blow (and stick to recomended fusing current values) If you over-rate any fuse you will cause further more serious damage to the wiring loom or start a fire! Once the offending circuit has been isolated you can begin tracing the culprit.
__________________ Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque. | ||
| | #3 | ||
| Re: 2004 hi Ffoxy sorry what citroen forum new at all this,have tried what u have mentioned i will wait to see if some one has had the same problem. thanks again
| | #4 | |||
Good Luck.
__________________ Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque. | |||
| | #5 | ||
| Re: 2004 sorry Ffoxy re the citroen forum do u have any details of one. regards
| | #7 | ||
| | #9 | ||
| Re: 2004 thanks for ur help have posted on preloved citroen as well
| | #10 | ||
| Re: 2004 have posted on preloved citroen as well thanks
| | #11 | ||
| blessed are the apostates | Re: 2004 its french, so its probably a short behind the fusebox. | ||
| Tags |
| fuse keeps blowing |
| | santa | Stilo | 18 | 21-12-2006 11:54 |
| 2004 GULF AIR BAHRAIN GP - Sunday 5th April 2004 | cinqmeister | Leisure Lounge | 8 | 06-04-2004 17:28 |
| All the best for 2004 | PandaManPaul | Leisure Lounge | 4 | 01-01-2004 22:05 |
| | Proc | Stilo | 6 | 15-10-2003 22:28 |
