Thread Tools
Old 4 Weeks Ago   #1
South Africa
1.2 mpi compression values needed
Hi guys, i just did a dry and wet compression test on my old Palio 1.2 mpi, 2000 model and found the following values:
Piston 1 2 3 4
dry 135 135 135 115 psi
wet 170 180 180 200 psi
What should the actual specs be, assuming the motor was new?.
What would you say is wrong with the motor?, it still goes great, doesn't smoke and is cheap on fuel(16km per liter)
Strydom from Moreletta is offline Reply With Quote Quote
Thread Tools
(T) Seicento MPI 2002. Total brake failure, help needed dx90 Cinquecento / Seicento 50 14-04-2017 10:07
(G) values? RobW Cinquecento / Seicento 7 12-08-2014 15:06
(G) Stilo 1.9jtd compression Test Help needed ceefox Stilo 2 01-12-2011 18:21
(T) Do all Mpi Seis have ABS - Mpi Airfilter question too... ronnieronson Cinquecento / Seicento 23 12-09-2007 13:58
(G) Re Sell Values Fiatnut Stilo 7 25-07-2003 23:51
