Thread Tools
Old 2 Weeks Ago   #1
Tommervyn has donated!
Northern Ireland Newbie
Hi all, just got a 2013 1.3 Mulitjet Sport from England and having some trouble with it. Looking for recommendations of garages who know Fiats well. Would also appreciate some help from someone locally who knows about setting up and using multiecuscan (got cables and downloaded software but can't get it to connect) Based on the Lisburn side of Moira. Issues with the car have been a "stop start not available, check engine" warning and black residue found on the bodywork around the exhaust with a visible but not bad puff when the turbo kicks in. Many thanks, Tom
Tommervyn is offline Reply With Quote Quote
Old 2 Weeks Ago   #2
1.3 mjet 500 sport
Kekybobo's Avatar
Kekybobo has donated!
Re: Northern Ireland Newbie
Hi Tom, in also a Tom with a 1.3 mjet sport living in Dromore. Take the car a good run up the M1. It's possible the dpf needs a regen. If the car has been doing alot if short journeys then the dpf could be clogged. When my dpf regens there's a proper bellow of smoke. It's like something from whacky races (I do have a tunebox connected). Also I've read on here that a low battery can cause stop start issues. A new battery may be required.
I have multiecu scan. I could meet you somewhere and plug it in to see whats up.
There's a fiat/Alfa specialist mechanic in Lisburn in the industrial park on the left as you head to Lisburn from the Moira rd roundabout. I've never dealt with him although another forum member in the panda section had issues with them regarding a dodgy timing chain change.
Likes Tommervyn liked this post
Kekybobo is offline Reply With Quote Quote
Old 2 Weeks Ago   #3
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Italian tuning required, get it warm and thrash it. Needs doing for at least 20 minutes for a full regen. What mileage has it done?
D
Old 2 Weeks Ago   #4
It's always more involved
John202020 has donated!
Stop start "could" be the battery but could also be due to another fault code.
John202020 is offline Reply With Quote Quote
Old 2 Weeks Ago   #5
Thanks for the replies and advice guys. So it was DPF blockage, had an error code P2002 Particulate Filter (2nd Clogg level exceeded) but on giving it a hard run up the motorway the sensor has fried with the heat of the exhaust gasses, probably too blocked to regen properly??? It's in the garage at the minute getting sorted. It has 41,000 miles! Will get the battery checked when the DPF is sorted but airbag sensor light came on too!!! not having a good run of it am I???
Old 2 Weeks Ago   #6
Whilst a bit young the engine earth strap can corrode and cause issues with all sorts cheap and easy to replace (under battery tray) if you do get a new battery shop around it won't be cheap 100 or so, not sure if the Batterymegastore deliver in Ireland worth a check?
Old 2 Weeks Ago   #7
Thanks John, I'll check this out!!
Old 2 Weeks Ago   #8
1.3 mjet 500 sport
Kekybobo's Avatar
In regards to batteries give this guy a shout.
http://www.4ni.co.uk/c/126877/the-ba...man-ni-dromore
He works out of a Van now so he can come to you. Decent fella and not hard to pay.
He sorted my better halfs car. 1.4 tdci fiesta. All electrics worked properly but the car wouldn't crank. A new battery sorted it.
Old 1 Week Ago   #9
Thanks Tom, will give him a shout when I get the car back. On the multiecuscan front, the lead I got was a dud, sending me out a new one Maybe give you a shout in a couple of weeks??
Old 1 Week Ago   #10
1.3 mjet 500 sport
Kekybobo's Avatar
Quote Originally Posted by Tommervyn View Post
No problem at all. Anytime.
Tom
Thread Tools
Northern Ireland Mechanics? SB1500 Garages 7 07-09-2016 21:09
Who's all from NW Northern Ireland? SB1500 Leisure Lounge 0 15-02-2016 10:55
northern ireland newbie :) j4me5y Newbie Central 0 16-01-2012 18:39
hi from northern ireland nidee500 Newbie Central 0 31-10-2010 12:03
Northern Ireland Jordan FIAT Boo Archives 3 13-04-2004 17:00
