Lamps by Post - For all your lighting needs
Thread Tools
Old 23-07-2017   #1
Replacing Steering wheel with same nut/washer
Hi All,
I need to replace the clock spring on my indicator stalk (horn not working except when turning wheel left). My MOT is coming due next week and all my workarounds are not holding.
My Haynes manual says when reattaching the steering wheel you must use a new securing nut. Has anyone else experienced this and had to use a new nut to secure the steering wheel? Or, can you reuse the same nut?
Thank you all in advance for your advice!
Nipsey is offline Reply With Quote Quote
Old 23-07-2017   #2
varesecrazy has donated!
Re: Replacing Steering wheel with same nut/washer
Quote Originally Posted by Nipsey View Post
Hi All,
hi,
still got an airbag..? that's a shame..
my old TIPO did this - it had worn out the slip-ring.. so I turned the wheel upside down..
perfect for MOT's since then
Old 23-07-2017   #3
Thanks for the reply. No airbag and that is the problem trying to find a replacement clock spring.
So turn the steering wheel upside down will fix the problem? Can I reuse the securing nut or do I need a new one per the Haynes manual? It looks like I can reuse the nut but wanted some advice. Thanks!
Old 23-07-2017   #4
Trader Rating: 1
portland_bill has donated!
I used a new nut when I disturbed the Panda wheel, but seem to remember that it seemed tight enough to re-use. It is a strange self-locking type that is less effective each time it is used. I think it was quite cheap from the dealer, so if there is one near you, get a new one. If can't wait, re-use and don't worry.
13 years motor trade, 16 years motor industry. 13 years Driving Instructor & 6 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 24-07-2017   #5
MOT tests tend to be on a ramp.. so wheel is basically "straight ahead.. "
also - reminds me of a 127 we had.. if you got cut-upon a roundabout
you HAD to swerve to honk the horn..
Old 26-07-2017   #6
Spain
You can safely ignore anything you may read between the covers of the Haynes manual on the Fiat Punto, and in any other Haynes manual printed since they began saving money with cheap and nasty paper, poor quality diagrams and photographs, and since they stopped researching and compiling them properly, using an existing car as a basis, a knowledgeable mechanic to do the jobs, and following up all reasonable model variations. I have in the past written to them complaining about errors and omissions in this very manual, in particular regarding the 2 different manual steering racks that were used and clearly not known about by Haynes. They told me when I complained that gearboxes were not covered at all except with a few worthless sentences, that market research has told them that the buying public do not want to see gearboxes covered! I would like to see that market research published! If you need a service and repair manual the factory version if available will be your best bet despite the high cost.
Any self-locking nut will lose its effectiveness with repeated use, especially the crushed ones as opposed to those with a circular spring or a nylon insert. Fiat love these crushed nuts, used on the Punto on the rear stub axle nuts as well as the steering wheel. But you can easily put a few spots of Loctite on the thread if you are worried, or even a smear of Araldite. However if the nut is tightened up to correct torque you have no need to worry at all about its coming loose. If it did slacken off you would become aware of it before there was any danger.
rolandbrindley is offline Reply With Quote Quote
Thread Tools
(G) Alloy wheel nut washer! Chalmers86 Punto (Mk2/2b) 6 07-10-2011 14:06
Steering wheel nut? Tupe FIAT Boo Archives 9 29-04-2010 22:55
(S) steering wheel nut unimatrix1 Punto (Mk2/2b) 4 31-01-2010 14:25
Steering wheel nut sz? nico FIAT Boo Archives 4 08-08-2009 15:41
(G) Steering Wheel nut size? seicento_minto Cinquecento / Seicento 0 17-05-2007 16:34
