Thread Tools
Old 1 Week Ago   #1
Punto Gearbox trouble..
Hi all.
I have an 02 Punto 8v with 68k on the clock. It's developed a knocking noise from the gearbox when stationary that disappears when the clutch is pressed.. and rumbles when the car is in motion. I have changed the gearbox oil today and it's no better. Reckon the gearbox is on its way out? I can get a reconditioned box and clutch fitted for 240, but considering I'm an apprentice on 3.40 an hour it's not exactly going to be, erm, easy... does anyone have any recommendations on what to try before I borrow the money to have the box and clutch done? Thanks!
Jordanmk2bua is offline Reply With Quote Quote
Old 1 Week Ago   #2
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: Punto Gearbox trouble..
Quote Originally Posted by Jordanmk2bua View Post
Hi all.
Do you get any noise when sat at idle?
A rumbeling / sorta ratchey noise?
But goes quiet when clutch is pressed downn (released)
As ive developed this noise yet again!
Everytime ive thrown a clutch and gearbox in and the noise goes away for a while
However due to travel soon whilst towing i couldnt risk a breakdown really...
So ive gone to examine the box and that
And well - turns out my clutch was a fault..
The boss(the bit with the internal spline) on the center plate (friction plate) had worn abit and could move about 3-4mm slop allowing the release springs in the pressure to rattle around...
So new clutch and im off again!
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 1 Week Ago   #3
Quote Originally Posted by Ziggy122 View Post
Ziggy
Mine makes a slight knocking on idle and goes when clutch is pressed, and rumbles when car is moving. It's never had a box in its life so I wouldn't be surprised on mine. Been told it's either; thrust bearing, input shaft or seals.
Old 1 Week Ago   #4
Hi that's good information. I have a 03 punto al look out for that, enjoy your day. My regards Phil Wood.
Phil wood is offline Reply With Quote Quote
Old 1 Week Ago   #5
To be honest, I can't see why the gearbox should be at fault. Sure, a gearbox can develop whines and rumbles but in reality they tend to soldier on for vast mileages.
If the noise goes away when you depress the clutch the fault is in the clutch assembly somewhere. If there's an occasional whine or screech that points towards the thrust bearing.
Personally, if it was my car I'd take the cheapest option first and change the clutch - all 3 parts .. bearing, driven plate and pressure plate.
You'll probably get the parts for 50 on Ebay:
http://www.fiatforum.com/grande-punt...ml#post4279586
glenn2602 is offline Reply With Quote Quote
Old 1 Week Ago   #6
flisko's Avatar
flisko has donated!
just drive till it pops
flisko is offline Reply With Quote Quote
Old 1 Week Ago   #7
Charlieboy13 has donated!
Hi all.
Hi Jordan,
We had this issue with my wifes punto, was the clutch bearing.
Changed the clutch along with the bearing myself.
You can get a clutch kit for under 80 at Euro Car Parts.
Charlieboy13 is offline Reply With Quote Quote
Old 1 Week Ago   #8
Quote Originally Posted by Charlieboy13 View Post
Hi Jordan,
Dont for the love of god buy transmech
They are refubrished, not new
They will fail fast again!!!
Ive just brought a new clutch through shop4parts ans the ff memebers discount
Was like 60 delivered for a valeo clutch
Ive had several LUK clutches and they have all failed in the same way - rattlin/rumbelling which would go away on pressing the clutch
My release bearing was in good nick and so was the pressure plate
Valeo went into my mrs and again no issues there either!
Ziggy
Meet Bumble-Bee
Old 1 Week Ago   #9
Ziggy
I got a Valeo also mate. Think it was 79.99 at Euros. Would use shop4parts but they had none in stock.
Old 1 Week Ago   #10
Spain
If the clutch friction plate has shock absorbing coil springs running around the central boss and you can move them round with your fingers, you need a new friction plate no matter what the friction surface is like for wear. These springs get weakened with heat and long use and become loose in their pressed steel housings. Sometimes they make a jingling noise at idle in neutral gear which goes away when you press the clutch. I took off the rubber plug from the bell housing and with a long thin tube on the can sprayed some WD40 onto the friction plate through whatever holes I could find in the pressure plate. Didn't do the clutch grip any harm and it shut those springs up. Eventually I'll need to change the clutch as it's showing nearly 150,000 kms.
Likes Charlieboy13 liked this post
rolandbrindley is offline Reply With Quote Quote
Old 1 Week Ago   #11
If it was Input shaft, then it would still make the noise with the clutch pressed. I had an Input shaft bearing went on mine and it was noisy no matter with or without clutch pedal pressed also the seals had failed. If the input shaft seals go then you get oil in the bell housing which makes the clutch slip.
Cheapest fix for that is a new box which is what i did,
However what you describe sounds more like just a clutch issue,I would guess the cause is either the Clutch Thrust Bearing or the anti chatter springs.
Replacing the Clutch is a whole lot cheaper than replacing the box
Scudmonkey is offline Reply With Quote Quote
Old 1 Week Ago   #12
Cheers everyone. Getting a quote tomorrow for a new clutch.
Jordan
Old 1 Week Ago   #13
For ths love of god!
DONT USE WD40 OR ANY OIL BASED PRODUCT ON YOUR CLUTCH
It will cause it to slip! And it will ruin the clutch
Ziggy
Likes dank86 liked this post
Meet Bumble-Bee
Old 6 Days Ago   #14
Thanks Ziggy, i missed the post where the guy used WD40...
I guess he used the old engineering flowchart....
Old 6 Days Ago   #15
flisko's Avatar
flisko has donated!
tape+wd40 = nuclear reactor
Likes Scudmonkey liked this post
Thread Tools
(T) gearbox trouble punto sx60 selecta kimmie55 Other Fiats 5 30-12-2011 03:39
(T) Gearbox Trouble flying dutchman Panda (Classic) 2 08-10-2011 12:12
(T) gearbox trouble scottie2065 Stilo 10 31-10-2006 15:10
Hello all and please help me!!!(Gearbox trouble) ady2006 Newbie Central 8 09-01-2006 19:59
