Lamps by Post - For all your lighting needs
Thread Tools
Old 29-06-2017   #1
Problems with steering column
Hi, I am new to the forum. I have just had a service done on my 2013 500L trekking and was told the steering column was loose and it would need replacing at a cost of 800+. It is the third service it has had and this is the first one to highlight a problem.
They said it was the car had been driven offroad or over speed bumps a lot. the route to my home has 14 speed bumps each way!!!!
Is this something that is common? Is this something that can be minimised? Is it caused by having the "city" setting on my steering?
Help please
Alertdriver is offline Reply With Quote Quote
Old 05-07-2017   #2
Re: Problems with steering column
Hi just read of your steering column drama I must say I it seams odd and I think you should get it checked elsewear.The MOT check is usually to see if there is any play in the steering wheel up down left right and it is due to huge mileage! speed bumps ect I would expect to cause wear to ball joints track rod ends springs long before the steering rack or column.There are plenty of 500l's breaking for spares on the Bay or may be repair your's if it is worn bush bearing under the steering wheel?.
Telegraph is offline Reply With Quote Quote
Thread Tools
(T) Panda Steering Column Problems power steering guru Panda 3 14-03-2017 18:55
(T) Steering Column Replaced Twice but Still Have Power Steering Problem!! emilyc Punto (Mk2/2b) 18 06-12-2014 00:43
Punto (Mk2/2b) Full Electric Steering Column & Power Steering Motor seaneb2003 Auction Watch 0 22-05-2013 09:14
(T) Punto electrical steering column/power steering fairview7 Punto (Mk2/2b) 3 19-02-2011 20:33
(T) steering column problems ? ArberMehmeti Punto (Mk2/2b) 4 26-05-2009 16:13
