Thread Tools
Old 06-06-2017   #1
South Africa
Cooling Welsh plug replacement '94 1100 Fire problems
I have a problem fitting the Welsh/Core/freeze plug on the side of the block, it is between the Cam belt and Tensioner, I bought a new plug for replacing and the dimensions seem to match, the old one came off without much trouble, however Upon fitting the new plug I tried using the old one as a guide to knock the new one in, I went further by tapping it on the sides to try make a solid seal but there is still a leak and this plug is able to pop off under minimal pressure.
I went further to tap the inner dome on the plug in the attempt to create a flair in hopes it would seal, but to no avail. I what am I doing wrong and is there a specific method of installing this?
Slave to Money. And then You Die.
DartonStaker is offline Reply With Quote Quote
Thread Tools
(T) 94 Uno Fire 1100 core plug (Pictures added) maxi26 Uno 7 10-06-2017 20:24
(T) Panda's 1100 FIRE in Marbella? How? mudoje Panda 4 24-09-2013 20:08
Uno Fire 1100 Stefanie Kleynhans Tech Talk 1 28-01-2013 16:07
(T) turbo in 1100 fire?! VoX Uno 3 23-01-2008 16:01
(G) Uno 1100 Fire UnoMia Uno 1 19-12-2007 08:42
