Hi
Just bought a 1999 Barchetta and have now joined the club.
I have a problem with my speedometer.
The kilometer counter works OK, but the MPH will only register up to 50.
Anyone got any ideas.
Thanks.
I agree that a cracked solder joint (a common problem on the B) might be the cause, but more typically, doesn't it stop the speedo from working altogether? It's hard to see how a cracked solder joint would be sensitive to speed, to the extent that the speedo routinely stops working once you hit 50, and starts again once your speed drops below 50. Very puzzling. It's not something simple, is it, like some foreign body in there, physically preventing the speedo needle from rotating beyond 50?
Hi
Hopefully it is the gearbox sender.
Where on the gearbox would I find it?
Hence the suggestion of seeing if the odometer is similarly effected.![]()
No they fail exactly like that, I can guarantee that there isn't any other problem!
The solder joints are crap in barchettas on speedos!
Mine always stops working when the car's been parked in the sun. Classic symptom of a cracked solder joint opening up due to heat expansion. It used to bother me, but now I just calculate my speed from the tacho. That way, I get to practise my mental arithmetic while driving, in an attempt (probably fruitless) to stave off premature senility.![]()
