Lamps by Post - For all your lighting needs
Thread Tools
Old 13-04-2017   #1
problem with power steering
Hi - steering light is coming on on the dash board and at the same time the power steering's power is reduced massively. This is an intermittent problem.
Teresajohnson is offline Reply With Quote Quote
Old 14-04-2017   #2
varesecrazy has donated!
Re: problem with power steering
Quote Originally Posted by Teresajohnson View Post
Hi, and welcome,
the elderly fiat Bravo/a have hydraulic power steering.. generally very reliable
I suspect you have a 2006 to 2012 fiat Bravo - generation2
essentially a "BIG Punto"..
read this PAS guide - covering the very similar Electric assistance system of the punto,
http://www.fiatforum.com/punto-ii/34...tart-here.html
Charlie - Oxford
Old 22-04-2017   #3
same problem here, panda 1.1 2009.
I had my power steering drop out when i was on a roundabout in Bradford of all places, got it booked in monday to see what the issue is, got an EML light on as well.
Noble Panda is offline Reply With Quote Quote
Old 02-07-2017   #4
Finland
When I had these symptoms in my 2001 Brava 1.2 the power steering fluid pressure sensor was leaking fluid. I replaced the sensor with a bolt and an O-ring seal: problem solved.
Leifhackman is offline Reply With Quote Quote
Old 03-07-2017   #5
bluejohn125 has donated!
There are several different types of power steering depending on model and engine, so you really need to specify all details before expecting helpful responses.
They will all be pretty old and worn by now. I've changed the pump on my 1.2 a couple of times now, plus the pipework when a switch started leaking. A new / recon pump will be over 150 from memory.
I'm not aware of any warning lights on the dash for these cars.
bluejohn125 is offline Reply With Quote Quote
Thread Tools
(T) Steering Column Replaced Twice but Still Have Power Steering Problem!! emilyc Punto (Mk2/2b) 18 06-12-2014 00:43
(G) Active Sport Steering gone really light.. power steering problem? andyleem Punto (Mk2/2b) 6 13-05-2011 11:59
(T) Power steering problem :( urkozamanje Punto (Mk2/2b) 6 15-09-2010 12:55
Power steering problem stacey b Lets Talk FIAT 2 17-09-2008 10:06
Power Steering Problem Stephen FIAT Boo Archives 2 11-05-2005 17:04
