Lassie1970
- Feb 28, 2014
- 8
- 3
Hi to all. I wonder if anyone can advise a non mechanically minded female with a dreaded power assisted steering question? I have a Punto Dynamic Speedgear 16V (2003) which had an occasional fault with the PAS light appearing and steering becoming heavy on tight left turns. This is now happening in normal driving and the steering wheel is often shuddering/vibrating when idle/sitting in traffic. At other times it drives perfectly but the more breaking/stops I have to make on route, inevitably the shuddering occurs and the light then appears shortly afterwards. I believe the steering column is to blame but could the shaking be due to mounts, etc? I do not want to part with my dear old car and have it booked in with my mechanic next week. If the steering column is to blame would I be better sourcing coded parts myself or contacting one of the firms offering 'self calibrating remanufactured units with a lifetime guarantee'? Having done a parts search I was offered a compatible steering column and ECU for £70. I am anxious not to waste money and still not have resolved the problem. Any advice on this would be most appreciated!
