Hi Paul,
diesel pushing back !? Whatever they meant with that I would translate by " don't know" Did they fix something or was it just a diagnostic ??
You say you're new to this, that's fine, you'll get soon used to the basic "rules" on the forum... So let's expand a bit:
- 1.3 mjt 90 has a turbo with moving vanes, while the 75bhp has wastegated turbo.
- the moving vanes are there to "regulate" the turbo pressure (boost).
- thery are actuated by vacuum.
- the vacuum is generated by a pump and shared with the braking servo.
- this vacuum is stored in an accumulator, for the vanes only.
- an electro-valve controls the vacuum actuator that moves the vanes.
- this electro-valve is driven by the ECU as follow.
At low engine speed and low load, the vanes are oriented so get the turbo spinning with little exhaust gas. This allows the turbo to react "quickly" to any gas increase (take off).
At high speed / load the vanes are oriented so the exhaust gas flow goes almost straight and without reaction on the turbine blades, thus limiting the boost pressure.
They're also used to create an artificial "engine brake" during deceleration by "blocking" the exhaust.
When allowed by the electro-valve, the vacuum stored in the accumulator pulls the actuator membrane that itself moves the vanes lever accordingly to ECU's request.
One component of that chain being bad, you'd have power loss issue. Engine light would also probably pop-up on the dashboard.
Before going further in finding the problem, we need to know how confident you'd be with rolling-up your sleeves and spending some ££ in
MES/FES/ELM ??
This
MES/FES piece of software will allow you to check almost the entire electronics on your GP and almost all other Fiat models aswell as Alfa's and Lancia's for less than 100£ and really is a MUST for any Fiat enthusiast...
Regards, Bernie
If someone here helped You fix or understand your issue, hit the thanks icon @ bottom right, it's free and make us happy ...
