wildgeo
- Apr 2, 2017
- 8
- 6
hi thanks for the connection to the forum,, appreciated,
long story of why im asking this but can a clutch for on a ducato 2.8 jtd 2001 Bend? il remove this week coming however what a night mare this saga has been ,, gear sync started not going into gear months befor clutch cable snapped then replaced cable then when replaced shifting into gear was almost impossible,,
swapped over gear box,, same issue,, ended up the fixing grooved rings on both the selector cables sleeves where snapped ..
so after all this and new clutch and swapped gear box and new selector cable system fitted,,
can only get ointo gear when engine not on,, clutch bearing or clutch il check this week however befor i do this has anyone experianced or changed over an original brass clutch pulley fork, because its bent.. should also add fitted new clutch pedal as the plastic hooc that attaches to the clucth cable snapped again long story on why,,
any ideas on this,, thanks appreciated,
