Uno Only starts maybe once a day
detol
Hi all I got a fiat uno hatchback 1995 think its a mk2 i have had it 2 months now and the problem is it starts every morning but go on a short journey and may not start again engine turns over ok but will not start i have changed the chip for a new one and changed the fuel filter the garage checked the fan belt unit and that works ok it has got good sparks on plugs the odd thing is i catch the bus to the car the following day and it starts strait away no problem and it drives well drive it back home a couple of miles and wont start again if you guys have any ideas as its driving me mad i have very little knowlege about engines so any help would be great many thanks for any help cheers have a great day all
I want to use it on further journeys but when i cant start it again it makes it harder to get back home its so unreliable that i can only do short journeys in it you stop to get petrol and it wont start again but its worth a a check on the sensor thanks for your advice
My 1993 Uno Fire developed a similar fault... would not start when hot - but once going it would get me to work (20 miles) but stop on the way for more than a couple of mins and it did not want to start.
I had a spare engine and sensors at the time and I just about swapped them all... no change.
Thinking back the only thing I didn't swap was the coil.
Never did fix it (n)
Hi good morning yes sounds like the same fault when its running its great but stop and thats it going nowhere many thanks you have been a great help i will give the coil a change and see what happens cheers have a great day
Hi good morning many thanks for the reply just been out and it would not start when i stopped plug was dry and brown Many thanks for your help have a great day
