On A250 2.3 multijet 150 Ducato where is the oil filter located please. Also the large equivalent of jubilee clips on the Airbox system, how do they come apart and refit? Thanks.
The oil filter is fitted to the engine block of the side facing the radiator. I do not know why you want to remove the air filter tube clamp as the air filter cover can be removed without touching it. In any event it is sealed with a tool and you may not be able to reuse it. There are large jubilee clips that will do the job though
Sorry, should have mentioned a severe mouse infestation nest in box half of filter chewed to bits, didn't go further but nest and dead bodies extends into intake tube, needs to come off to clean. trapped about 20 so far but 2 bait boxes down killing em off as well. Mice are a real problem this year, still breeding and natural predators are no longer about.
Been there, got the T-shirt. Most of my sound-deadening felting has gone. On one occasion after a winter in my friend's agricultural shed, I discovered a deer foreleg with hoof under the air-filter box. Pine Marten!
Either that or a high speed collision I was not aware of.
