Where do I start, the car occasionally cuts out but the power is ok, I have removed the throttle control body, cleaned and replaced, I have checked all the breather, vacuum hoses and all good, so I performed a diagnostic check and came up with 3 fault codes P0106 ( MAP sensor) P0335 (crank shaft sensor) new one put in yesterday P1010, so could you point me in the right direction to get this sorted the cheapest way
