Hello and help with indicators - Multipla
filter99
Hi all, I have been reading a lot of posts on here after getting my Multipla
Now, I have an issue (shock, I know)
The indicators on the left hand side are sticking on, all three, even with the ignition off, for now I have removed the hazard warning fuse so they dont work and neither does my remote. (indicators still work)
I have changed the flasher relay and this has made no difference.
Help please
05 newer shape 'pla
Andy
Hi. You could try taking the rear light cluster off and cleaning the unit getting rid of any crud(grey coloured) using a BRASS wire brush.Take out all of the bulbs ,not just the indicator one and give a good clean ,also clean inside of the bulb holder. Then clean the connecter. You can give it a spray of WD40.I tend to use a small amount of good copper grease.
Thank you - I shall give this a go, just have to climb into the boot to open it lol, needs a new switch assembly, when i bought it, it was broken and rattling around lol
someone else mentioned that - now the question is - how do i get that off to check eep
Hi! I'm having an issue with the indicators and hazards lights that are not blinking, could you please tell me where the flasher relay is located?
Hi, yes its in the fusebox towards the back, it is a pain to get to
Is it somewhere over here? Or is in the other fusebox? This is the fusebox under the glove's try on driver's side. I have no clue where to look.
