Lamps by Post - For all your lighting needs
Thread Tools
Old 06-02-2017   #1
USA
Plug and points
Hi everyone! I'm new here, hello hello! I just got a 1982 126p 650cc. It's yellow 😁 Anyways as typical fiat fashion it's needs a bit of mechanical work. First 5 miles drive shaft went. Then 2 weeks later the coil wire broke so we brought it to a mechanic to get it tuned up. He got a carb kit for it and adjusted the carb but when we got her back she drove great until we went to restart her. A friend had a look and said the engine had flooded and the carb seemed to be running too rich. He wants to know what the plug gap and point gap is. I got the ignition timing manual online but am having trouble getting the gap info. Thanks for all yer help!!
Orlaigh dufficy is offline Reply With Quote Quote
Old 06-02-2017   #2
Ireland
Re: Plug and points
Welcome to Fiat Forum
Afaik the spark plug gap is 25 thou (0.025 in.)
and the points gap is 12 - 16 thou (0.012-0.016 in.)
(these were the figures on the 126 in 1979, I'm sure someone will chime in and correct me if I'm wrong!).
Al.
The more you know, the less you need.
If what I write is helpful please click on the 'thanks' button, (smiley face on lower right).
F123C is offline Reply With Quote Quote
Old 06-02-2017   #3
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Plug and points
A carb running rich would have nothing to do with points or plugs, unless the plugs were dripping wet, then it wouldn't matter how big or small the gap was.
He hasn't put a carb for an upright engine on a lie flat engine has he?
D
Thread Tools
(T) spark plug thread gone and plug won't seat mikehopper Punto (Mk2/2b) 3 28-02-2016 09:38
Cinquecento HELP!!sump plug and plug sholding sleeve broken. dazza121 Members Motors 11 19-07-2012 18:48
Fiat 500 good points, any bad points? Alski Newbie Central 1 13-09-2009 09:48
(T) Gearbox oil change; drain plug & fill plug? combwork Multipla 3 03-07-2009 09:50
(G) have you seen a thing you plug in to cig lighter and has plug on other end fletcher11 Punto (Mk2/2b) 3 20-02-2008 13:16
