Ryan121088
- Feb 5, 2017
- 2
- 1
Hi everyone , I'm new here and new to fiat ownership , always been a vauxhall man till now and not many vans compare to these .
I have just purchased a 08 fiat scudo with 71k miles . 2.0 120 rather then the 1.6 as I will be loading the van with anything upwards of 600kg daily so the 1200 payload really helps .
I have just figured the bloothtooth out and next question is how does one see average mpg and instant mpg display / is the function available on the comfort model ( do have the manual but my van doesn't have the button on end of the stalk).
Assuming my van isn't fitted with this can I add it and what parts are needed ( I understand many lower model vans share same wiring ect and those with better spec and basically don't have the button but electrics ect would support it ).
Where would be best to install a leisure battery for work ( will be wired up with a split charge relay ). I assume in the back with the system is best place as unsure about space under seat ect p.s the battery seems to be under drivers floor (unless this is a second aux battery ).
Also any other plug and play things I can add to my scudo from a better model that will be supported will be appreciated. More gadgets ect the better ?.
P.s love my scudo goes like **** of a shovel and plenty of torque to allow the future purchase of a caravan ?.
