SkyBlueFiat
- Jan 19, 2017
- 1
- 1
I have a few questions about my new (to me) car. I've read the owner's manual but sometimes you just need things explained differently to understand.
1. Is it normal for the car to not 'creep' when in first gear? I've driven both semi-automatics and full automatics and both types have creeped forward.
2. Is there hill assist? I've tried researching this but can't seem to find the right answer. It's a 1.4L dualogic lounge model if that helps.
3. Is the correct procedure to park and start the car the following:
- Parking: leave gear stick in the middle (aka in 1st gear) and just handbrake and turn car off.
- Starting car: start engine, will beep to say it's in neutral, physically move gear stick into 'N', then move it back into middle into 1st gear.
4. Are you able to manually change gears when in auto mode as the car is moving or will this damage the gear box? Can you switch between auto and manual mode when moving safely or only when you're stopped? Can you switch the sport setting on when moving or, again, only when you're stationary?
5. When I press the brake it makes a "whooooosh" type of noise like there's air under the brake or something? (I'm not a car person, can you tell lol?) I've never had this with other cars and just wondering what this means.
Thank you!
Thank you!
