FIAT Auto Specialist Team
Thread Tools
Old 09-01-2017   #1
Indicator problems
My hazad lights come on when i indicate left. Any ideas. Thanks.
Nats17 is offline Reply With Quote Quote
Old 09-01-2017   #2
varesecrazy has donated!
Re: Indicator problems
Quote Originally Posted by Nats17 View Post
poor earth.??
I'd clean the connections to the tail lights 1st
Old 10-01-2017   #3
kazer92 has donated!
having a similar issue myself, my rear right indicator slows down when I brake, and braking with the headlights on it doesn't work at all!
have had trouble with that same brake light before so surely a connection/wiring issue?
'96 Fiat Punto Mk1 75sx - Scrappage Scheme Survivor & Daily Driver!
'98 Ford Fiesta Zetec GL - Boring Backup (SORN)
"A man with a fork in a world of soup" - Noel Gallagher on Liam Gallagher
kazer92 is offline Reply With Quote Quote
Old 10-01-2017   #4
ArthurM has donated!
Hi, take off the rear tail lights and take out each bulb and clean .Also clean the holders,removing all oxidisation. I tend to use a very smooth wet and dry paper. I then put one of those little satchets of silica jel at the bottom of the tail light away from any connections. This helps to absorb some moisture for a while.
ArthurM is offline Reply With Quote Quote
Old 11-01-2017   #5
I choose you!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Snowboard Slalom Champion, Skate Boarder Champion
agreed, this sounds like classic earthing issues. Clean the connectors and bulb holders out first - then if you still have problems move onto the actual wiring but my money is on some corrosion in the bulb holders. A dremel with small brass wire brush attachment is brilliant for cleaning out the bulb holders Remember to clean the bulbs themselves too if they are a bit manky too.
side note: welcome to FF @Nats17 More mk1 Puntos are always welcome
Charmander - Panda Mania 1242 mpi 8v - thread
Sully - 500 1.3 Mjet - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT
blu73 is offline Reply With Quote Quote
Thread Tools
Punto (Mk2/2b) Indicator problems! James MK2 Newbie Central 3 25-06-2012 19:09
(G) Indicator problems bravotony Bravo / Brava 5 26-01-2009 09:48
(T) indicator problems rickysanders76 Marea 6 08-01-2009 19:53
indicator problems tish FIAT Boo Archives 1 19-03-2007 14:38
(T) Indicator problems grey_bob Punto (Mk2/2b) 2 14-10-2006 19:39
