Thread Tools
Old 07-01-2017   #1
power steering motor
Hi All
Im a newbie here just got a punto having problems with power steering motor hope you can help
I have taken the power steering motor of the steering column leaving it plugged into electrics,when i start the car and turn the wheel it spins for about 2mins then stops (This is not right surely)shouldn't it keep spinning everytime you turn the wheel
gmoore1960 is offline Reply With Quote Quote
Old 07-01-2017   #2
Brendan W has donated!
Ireland
Re: power steering motor
Hi gmoore and welcome to Fiatlan
Mine does the same although I didn't wait two minutes. Just put it back and the steering worked again for a few months. Eventually I had to replace the relays in the motor.
What symptoms have you got ?
2001 1.2 8v
Brendan W is offline Reply With Quote Quote
Old 07-01-2017   #3
flisko's Avatar
flisko has donated!
flisko is offline Reply With Quote Quote
Old 07-01-2017   #4
Quote Originally Posted by Brendan W View Post
Hi and thanks Brendan
When I start the car the steering is fine for amoment then goes stiff as I said I have taken the motor off and left it plugged in you can see the spline spin when you turn the wheel but then stops and will not go until you restart the car
Old 07-01-2017   #5
Ireland
Simples first. Get the battery and charging checked out. The steering draws a lot of current and if the battery is weak, cold, with lots of other demands like lights especially after starting, the steering will trip out on low voltage.
2001 1.2 8v
Old 08-01-2017   #6
In my case the problem seem to be related to the motor wiring harness connectors. As the motor draws quite a bit of current especially in city mode the connectors with age weaken and start failing causing voltage fluctuation which the power steering ECU detects and then powersteering is disabled with warning light indicating. After applying some contact cleaner to the contacts the power steering started to work reliable.
I am interrested to know if the steering is lighter when the power steering motor is removed from the column.
I drove the car with non working power steering and the steering is very heavy not usable, at least twice as heavy as my non power steering Mk1 Punto.
The problem with the powersteering on the Mk2 is that it can fail while on a move and if it happens while cornerring I hate to imagine how to negatiate the situation.
dumbledore is offline Reply With Quote Quote
Old 08-01-2017   #7
Ireland
Quote Originally Posted by dumbledore View Post
Cleaning the connectors to the power steering and at the battery will help.
As for failing on the go there is this new idea the driving instructors have come up with. It's called putting the phone down and putting both hands on the wheel. It will be rolled out on a trial basis in 2017 subject to DoT approval.
Likes digger58, Qube O liked this post
2001 1.2 8v
Old 08-01-2017   #8
flisko's Avatar
flisko has donated!
mk1 got 13" wheels and is lighter than mk2
Old 08-01-2017   #9
Quote Originally Posted by flisko View Post
My mk1 has 14" standard allows, the tires are slightly smaller diameter as they are 165/65R14 instead of 165/70R14. Also the weight of the cars according to the manuals is same at under 900kg.
Thread Tools
(T) getting a new power steering motor *help* djandyh Punto (Mk2/2b) 1 01-02-2014 15:53
(T) help on power steering motor djandyh Punto (Mk2/2b) 3 31-01-2014 22:40
Punto (Mk2/2b) Full Electric Steering Column & Power Steering Motor seaneb2003 Auction Watch 0 22-05-2013 09:14
(T) Is my power steering motor on its way out david295 Punto (Mk2/2b) 2 15-05-2011 12:49
(T) Power Steering Motor and Steering Rack bridgit37jones Panda 2 27-11-2009 16:59
