Lamps by Post - For all your lighting needs
Thread Tools
Old 2 Weeks Ago   #1
Grande punto 1.4 8v
Hi!
Just bought a black 1.4 8v for my son
All good but now have eml on! Did scan it and said camshaft position sensor so changed it. Still the same. Disconnected battery. Still same .
No power at all and won't rev above 3500 rpm. I could walk faster!
Any ideas before I set fire to it?
Many thanks
Treadmark is offline Reply With Quote Quote
Old 2 Weeks Ago   #2
varesecrazy has donated!
Re: Grande punto 1.4 8v
Quote Originally Posted by Treadmark View Post
Hi!
Many thanks
after a cambelt change , the slightly less stretched belt means the signal from the top and bottom sensors are different,, hence the EML
either get the place that did it to realign the sensors properly,
http://www.fiatforum.com/grande-punt...r-60mph-2.html
or get a ProxyAlignment done
Old 2 Weeks Ago   #3
Andorra
Hi!
Many thanks
Hi, sorry for my english
check sensor crankshaft pulley
is magnetic and if changing belt and hit fault
omega22 is offline Reply With Quote Quote
Old 2 Weeks Ago   #4
Thanks for reply
Belt not been changed...
I cannot get it to rev beyond 3500, sometimes 4000 rpm
It's the weirdest thing ever!
Old 2 Weeks Ago   #5
Oh and that's not driving it. Just sat still...
Old 2 Weeks Ago   #6
Bump
Old 1 Week Ago   #7
Been told that this car only likes Bosch marelli sensors... Is this right? When I changed the camshaft sensor out it wasn't one of those!
Old 1 Week Ago   #8
Well new twist
Put another Bosch sensor in and still no power and still saying camshaft position sensor on bank 1... Guess it's set fire to the thing. Has NOONE got any idea what's going on. No power and won't rev past 4000 now and really feels like it's missing a bit on idle
Old 1 Week Ago   #9
Became old and sensible
brickfoot's Avatar
brickfoot has donated!
Well new twist
If you've tried another sensor then it's likely the timing is out. If the cambelt has slipped a tooth, then the ECU will flag a warning because the crank and cam sensors are out of sync, therefore limiting the power.
Only way to know for sure is to get it hooked up to a diagnostic that can give live information from the sensors and see if the cam sensor is giving feedback on the position. If it is, then the timing may be out, in which case, you'll be looking at the cambelt next.
MultiECUScan will give you the necessary info for diagnostic, and the software + cables are cheaper than a Fiat Dealership diagnostic.
Current Garage
Mine: 2006 Fiat Grande Punto Sporting 1.9 M-Jet
Hers: 2013 Fiat 500 Lounge 1.2 pile of crap
brickfoot is offline Reply With Quote Quote
Thread Tools
