FIAT Auto Specialist Team
Thread Tools
Old 24-05-2016   #1
South Africa
Change the water hose
How do I change the water hose that goes from the block to the water pump (I think) it is a short 90 degree hose. This is on a Strata 1.7D
Thank you
Khosa is offline Reply With Quote Quote
Old 22-06-2016   #2
FiorinoDan has donated!
Re: Change the water hose
Don't know too much about these ones, but if you look on the ePer link under fiat commercials you will find the cooling system layout. I presume that you want the small S type hose. Looks fairly straightforward. Remove the two clips and the hose, slip two new jubilee clips over the new hose and slip it over the stubs (washing up liquid helps). Top up the coolant and run to temperature to release any air locks.
FiorinoDan is offline Reply With Quote Quote
Old 22-06-2016   #3
varesecrazy has donated!
Quote Originally Posted by Khosa View Post
Thank you
Hi.
Maybe look under Palio section
The 1.7 wasnt used much in UK FIATs
Charlie
Thread Tools
(T) 1.9 JTD Water Hose matyers Grande Punto 0 05-06-2014 08:41
(T) Water hose BLUE VAN MAN Scudo 1 17-11-2013 18:13
(G) Burst Water Hose. cptcuddles Cinquecento / Seicento 6 25-10-2012 21:18
(T) Water Hose _ Bodge? Spank My Car Punto (Mk2/2b) 32 08-08-2008 14:52
(T) hose with water on dash??? cinqgirl Cinquecento / Seicento 9 15-10-2004 18:06
