Hi, I'm a newbie to this site and was wondering if anyone an help me with an HT lead problem.
I'm trying to do a spark plug change and can't seem to get the HT leads off of plugs 2 & 3; am I missing something? The HT leads came off of plugs 1 & 4 with no problems.
Thank you in advance.
Justin
Hi Justin, and welcome,
because you'd tagged your post Grandepunto..it's appeared in the GP section also.
OK = plug leads..no great secret..
they have a metallic part that clips around the plugs top,
and a rubber sleeve that fits snugly around the ceramic insulator
chances are it's the rubber that's REALLY well seated..
DO NOT just yank on the cable.. as it'll have a 50/50 chance of doing damage without actually pulling the rubber off,
there are special tools for pulling leads by the rubber,
but I've resorted to conventional pliers before,
pull the rubber - via pliers with one hand..and also the same pressure on the cable with the other..
I suppose you COULD try a hot air gun / hairdryer on the rubber to see if it'll soften and loosen it's grip.. but then it could be too hot to actually hold while removing..,
Charlie - Oxford
