So good bit of progress this weekend!
We went over the hills to visit John (Panda Panda) and check out his collection of Panda's, more specifically the Black CLX that he has for sale. I am beginning to wonder if there are generally less Panda's around these days or just less people who own them, who have a few! Quite a collection there. It was great to get out in the car (thank again John) including a blast down the motorway, certainly reassuring as to the Panda's capability on the trip, very little noise from the road, transmission or engine, just wind noise at higher speeds but no more than I'd have expected given the shape of the car.
There are a number of things I spotted while looking round the car which require further investigation:
Rear wheel bearings, on both sides made a knocking noise when the wheel was shaken. No noises were evident during the test drive so I've been advised this may or may not cause an issue on the test, MOT tester dependent. Either way if I go ahead and get this car I'd want to get them sorted so could do with factoring in the cost of 2 new bearing assemblies.
-The
rear seatbelt mounting on the right hand side was heavily corroded, looks to be a very easy repair but originally we were talking about John selling the car with a years MOT, which looks unlikely. Any thoughts on getting this through by removing the rear seats and belts? Once I've got it I can put things right quickly enough, plus there will only be 2 of us in the car most of the time!
-The
bottoms of both doors had quite a bit of rust but specifically the drivers door, the skin was a little rotten but the actual door frame itself was well gone all the way along the bottom and up to the lower hinge. All pretty well internal and nothing which would obviously maim a pedestrian though so hopefully nothing the MOT tester will worry about, I'll just need to factor in welding time/materials and paints etc.
-The central part in the
rear spring cup on the right hand side had rotten and looked to have come out of position a little (possibly only the spring holding it on). Again an issue more for the MOT but does mean at some point I need to get the axle off so bit more work to do.
-There was a
rattle when the car was at idle and the clutch was released though I'm reliably informed this is a common Panda trait and shouldn't be anything to be overly worried about.
The Heater is not working, John has swapped the heater from Fizzle on to this car and it was working prior so possibly just caused by an airlock? The radiator was weeping slightly so maybe that has caused the coolant level to drop to the point where this issue has occurred?
-As above,
slight leak on the radiator, not a biggie really given the radiators seem to be available for £30 but still another £30 to factor in to the overall cost.
In addition to the above the last MOT advisories indicate the following:
Offside Front Shock absorber has a light misting of oil. So again I know not expensive parts but all adds up.
Also as per Freddy (panda1408) who has worked on the car:
Hole in the nearside front jacking point. Missed this one, again welding work, all good with that. He did also report that structurally its in good nick, bit of welding on the sill but to a good standard.
So it is out of MOT and may struggle to get another one based on a few issues spotted (and quite possibly a few more missed out). John is putting it back in for an MOT soon (hopefully Thursday) so we'll have a better idea by then but I've then got to factor in parts required and
how I should transport it back should I choose to buy it. What are peoples thoughts on booking an MOT near home (or half way) and driving it back based on taking it to an MOT? The car is only 30 miles away, alternatively any thoughts on paying for transportation, ok there are some hills in between but it's really not far.
John will be breaking Fizzle for parts in the near future and has kindly said if I come and help him break it then if some of the above can be solved by swapping parts over then I'm welcome to them
With that in mind it's just a matter of what bits will be good to swap over and what would be better knew.
Other than John's CLX there is an older CL for sale on the forum from Fordy13, this is MOT'd and has had welding done which should see it good for several years MOTs. In many ways this car would be cooler to take, it's carb. not injection and it's nearly as old as I am
The fact it's MOT'd and ready to drive home is also a great plus. I need to contact Fordy13 again about this one! Negatives for it are, it's only a 4 speed (which has come up before and is only a minor negative) and it's quite a bit more expensive. Don't mind paying a bit extra for things being sorted like the bearings/shocks/radiator (in comparison to Johns) but I'd rather not be paying for welding already done, in part cos I want to do it, and in part cos if I've welded it myself I'll know the car better, save money and be confident in the welds!
Again I'll throw this out to the group to chew over for me (if you'd be so kind) as I'm still VERY new to Panda's!
