Panda panda not starting
chelbel83
Hi guys I have a Panda 2005 1.2 dynamic its done me well since i brought it in 2004/5 with only a few mechancal problems but this year its been not starting very well. it done it once a week to now every morning i have the same problem. i took it to the garage and they said the battery is fine , the starter motor is fine, my oil and coolent was slightly low but nothing that would stop it from starting any ideas?:)
Have you ever changed the battery? It might appear fine but in reality it might not.
Try adding more info.. is it slow..struggling to turn over??
If so when its struggling put a jumpstart cable from negative battery terminal to the engine metalwork..
IF this helps..you need a new main earth cable-battery to gearbox.
Charlie . Oxford
