Hi All. Can anyone please help. How do you separate the fuel injector common rail from the fuel injectors once the rail has been unscrewed from the engine.
How do you remove the injectors from their positions.
Post this question in the "Tech Talk" section on this Forum.
Btw, it's the same engine used troughout the Fiat range, so procedure should be the same...
