Nimblestraw64
Hello..
I'm certainly not the first to have this problem from this forum, I found you all by accident and have enjoyed reading and digesting your thoughts, views and advice.
I'll bring you all up to speed, short version, but you may want to get a coffee now...
Junior buys Stilo 1.6 16v on a 53 plate......car has done 136.000 miles is clean and tidy and has beenwell looked after. usual issues with this for its age shocks all round knackered, front tracking n/s well off, rear bushes probably non existant from sound and feel, front skuttle drains blocked, thermostat knackered, rear dampers knackered, stop laughing i'm not finished yet, drivers door panel buttons not working, drivers seatbelt torn, gear stick knob broken, and yes that dreaded airbag light. Not bad for 500 quid.
I have as i type only the bushes and wishbones to replace all else has been repaired to MOT standard by yours truly, except the light. Now this is were wee get to it. I have an Autel MD 802 does the job on telling me what i need to know on hundreds of cars including juniors. so far we have done 4 complete scans, tests, updated the unit as i've only just bought it and re done the tests again. heres what we got.
photo 1 shows some issue with onboard computer and airbag system to be all ok.....
photo 2 shoe=ws the code in more detail and a description of the code.
photo 3 again a fault found with instrumnet panel
photo 4 shows the live data stream showing clearly the airbag light is on yet system is ok....
I have also added the live data printout for the techies to look at nothing i can see stands out hopefully i'm wrong.
So far i have removed both seats checked wiring on both looms under each seat and all connectors, i did disconnect the battery as per guidelines. i have traced as best as possible the under carpet looms from the front to ecu for airbags no breaks or cracks. Steering wheel hauled off and contacts examined no issues there.
so simple questions why the light and what have i missed???? i'm guessing this is not the usual fault having trawled the forum. I am now in your hands.......
kind regards and thanks
Steve
Steve
