Doblo engine change wont start
seanlynch
iv changed the engine in my doblo 1.9 jtd and it wont start i used my jets and pump the engine lit is on
I changed mine and it started no problem.
Sounds like the crank sensor, try plugging it into an OBD 2 code reader.
engine light..? the RED one..??
does the immob / key code go out..?
does the tank pump run..??
a Crank Angle Sensor could well be a suspect too, as they don't tend to leave a fault code.. however the MIL should leave a code or two,
as stated reading codes could be good, (y)
also a better device running MultiECUScan could read rail pressures etc, ;)
Charlie
There is a cut out of thing on mine that tripped when the door blew open and hit a wheely bin with a bang... Just press the button by the drivers knee in a recess, on most doblos it is under the passenger seat. If it is that a warning light will come on but not the management light.
fuel cut-off switch ( to prevent fire);)
hence my suggestion of hearing tank pump run..,
Charlie
