R rikkie New member Joined May 29, 2015 Messages 2 Points 1 May 29, 2015 #1 hi having probs with my 08 doblo multijet i have changed fuel pressure sensor regulator and crank postion senson still not firing any ideas ???
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,979 Points 7,835 Location Near the M4 May 30, 2015 #2 rikkie said: hi having probs with my 08 doblo multijet i have changed fuel pressure sensor regulator and crank postion senson still not firing any ideas ??? Click to expand... Hi, and welcome, connect a code reader / scanner , it's the fuel rail pressures you really need with a "common rail diesel" any history of the vehicle, gradual adding to issues.. , any recent work done.., etc, Charlie - Oxford
OP OP R rikkie New member Joined May 29, 2015 Messages 2 Points 1 May 30, 2015 #3 hi had a pressure reg and sensor fitted just not firing tryed easy start still no joy could it be the glow nplug relay??........................
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,979 Points 7,835 Location Near the M4 May 30, 2015 #4 you need a proper reading of the pressures, or it'll not run.. pump failure is a possibility..
portland_bill Patron member Joined Feb 22, 2004 Messages 9,915 Points 2,854 Location Faringdon, Oxfordshire UK May 31, 2015 #5 Why change those two parts? What diagnosis has been done? Or were you just guessing? As Charlie says, needs proper diagnostic, otherwise we are all guessing. Is the stop solenoid not disengaging? Are there any warning lights on?
