Doozerstu79
- Apr 12, 2015
- 4
- 2
Hi guys I recently purchased a fiat uylesse 03 plate from a friend. She said she had had a problem with the earth cable and had it fixed, this was back in December. The car has not really been run since. I managed to tow the car to my drive and started to have problems. When I put the key in ignition and turn it once it says economy mode active I then try to start the car but it try's but no joy. The wipers and indicators do not work but the fob and locking system works fine. I have checked fuses and all seem ok. There is however a cable that is not plugged in to anything which I have found out to be throttle sensor. Does this need to be plugged in to something. Unfortunately I don't know too much about cars but have the savi to do what ever help anyone can give. If I need to list anything to help you helpe pls ask. I appreciate any kind of reply , help anything many thanks guys
Stu
Stu
