- Dec 1, 2014
- 11
- 2
Hi All
I am really amazed with the info I get from this forum and everybody seems to be very nice as per what i read from the threads..so I decided to join..I am also a new owner of a fiat seicento sporting 1.1..bought it about two weeks ago..its my first ever fiat..and I love it! problem is just about three days ago the temperature warning light suddenly came on it's dash..changed the thermostat, coolant temperature sensor and radiator fan switch but the warning light still turns on when hot..i also have bleed the radiator following the guide i found here but still the same..there is no oil in coolant, does not leak or go low on coolant either..it starts fine and seems to be ok..fan does kick in as well..any suggestions what i may still need to check or replace? water pump is new also and coolant in expansion tank does swirl..i have not taken the sei on the road since i had this trouble just in case..
