Hi Guys,
I wonder if any of you had a similar problem in the past and might be able to give me some ideas please... I drive a Bravo 1.4 T-jet 150 and the coolant is leaking very badly I have to top it up in every 2 days and since the cold weather started it has got even worse -noticed that it loses more water when the temperate drops. It drives fine and i check the oil and the coolant very often and it's all clean.
I noticed some coolant right below the water pump earlier this year and had the water pump and thermostat replaced about 6 months ago but it hasn't stopped leaking Now i can't see any leak in the engine bay only this pink-orange deposit (see picture)
Last time when i had a service Fiat told me that there is a 'slight' leak on the union seal!? Does anyone know what and where that is?? Or could it be the pipe going into the turbo? I heard that is a common problem with the Bravos.
I attached a picture to this post, please if you have any ideas where the leak is or experienced the same problem before let me know. I would really appreciate it before i take it to the garage. Thanks in advance!
