Bravo ecu pins numbers
dtwelve
Member
Near doncaster
hi all after 3 unsuccessful attempts to do the cruise control has anyone got the ecu pin numbers and which ones for doing it someone gave me the numbers but it hasent work haven't even got the cruise light on the dash so somethings wrong
help plz before it gets too cold to do work outside
fiat bravo 2007 1.9 multijet
Depends on whether you have the 8 or 16 valve engine, they are ALL different.
My eLearn shows they are the same for the 16v and the 8v:
here's the 8v: Bravo 1.9 jtd 8v.PNG
and here is the 16v:Bravo 1.9 jtd 16v.PNG
cheers aurick I checked again this afternoon also checked to make sure the stalk was working proper still no cruise control, im just mystified why its not working :(
Do you have the 8v engine??????
Are you sure you're putting 12v to the stalk on pin 2?
Are you getting 12v out of the stalk on pin 4 going to the ECU; all the way to the ECU pins???
horay finally sorted found the problem the pins I was using didn't connect so bare wires straight in bingo working :)
If its anything like the Stilo they are pretty much plug and play. The cruise control stalk from a 147 ( I think) is the same (not sure of the connector block though) . I have one sat in my drawer somewhere as i never got round to fitting it .
Cheers for now
