Hi Guys. Im new to the forum so any help or info would greatly be appreciated.
I have a 2005 Fiat Punto Mk2 1.3 JTD Multijet. I have been driving this car for the last 6 months without any problems. Car has 200000km on the clock. For the last month the vehicle has been giving me issues when trying to start. It will crank over fine but not start. After 5 - 10 minutes of consistent cranking she will eventually light up and run really well. It will start up fine a few times thereafter, then after being parked for sometimes 10 minutes or longer back to the cranking trying to get her started again. It almost as if there seems no spark (I KNOW ITS A DIESEL)
Things I've done thus far :
Diagnostic gave 2 faults
1 : RPM Sensor Fault (Crankshaft)
2 : Intermittent Key
After clearing the faults only the RPM sensor fault came up
Dealership in SA takes 3 weeks to get a sensor so referred me to
a reputable company who deals in aftermarket sensors. Took the
sensor to them, the guy there was nice enough to test the sensor
and told me it measured 780ohm which is correct for the sensor.
I then went home traced the wires form crank sensor to the ECU
and measure it to ensure that I was getting 780ohm to the ECU and
this checked out fine.
Glow Plugs Changed
Glow plug Relay Tested
New Battery
New Diesel Filter ( Air Was Bled form system)
Now i'm lost and not sure what to check next. have I overlooked
something ? Like I say the car cranks and some times you can feel
she wants to light up but does not.
Glow Plugs Changed
New Battery
