Bravo hi-di-hi
Bravo hi-di-hi
dtwelve
Member
Near doncaster
Hi all just got a 57plate fiat bravo 1.9multijet only done a few miles yet and still getting use to the long gear lever stroke and handbrake (I came from Renault scenic)
upgrades coming up
hid headlight kit
rolling road tune up(anyone recommend any good ones in Yorkshire )
k@n
cruise control if I can find the stalk that fits
and spare wheel
cheers for any input
david
Welcome to the forum buddy!
I have the same model as you but on a 58 plate. I've already done the HID kit, LED side and number plate lights.
Where abouts are you from? Get some pictures up of the beauty.
What colour is it?
You'll find plenty of nice guys on this forum. If there's anything you need to know then ask away! :)
Jamie
upgrades coming up
hid headlight kit
k@n
and spare wheel
david
Hey dude,
Ref your stalk, I last week purchased an Alfa 147 stalk, fitted perfectly and wired it to the ECU. Works brilliantly (y)
hey brad where abouts r u as I thought it was just plug and play don't fancy messing with the ecu
Wolverhampton mate.
It depends which bravo you have. Some have the loom under the steering wheel. I have a 1.9 Multijet, and it didn't have it.
Dude so you mean you didn't have cruise control,so brought a stick for the alpha,and connected it up to your steering wheel and away you go?you got a pic
In a nutshell yes.
It clips (screws) onto where the indicator mount is, I'll take a pic tomorrow. I need to order a new bottom plastic bit for the wheel as the old doesnt fit and i cut it to make it, and I'm not too proud of it (n)
I wired a wire into the engine bay and put 4 pins into the ECU, and a 5th from a 12v supply.
Not an easy task I must say it took the best part of an entire evening (most of which was getting the cable through the bulkhead, gah that was hard work)
If you have a bravo that's prewired I believe it is literally plug and play! Check for the loom under the steering wheel its a white plug I'm led to believe.
In a nutshell yes.
Yeah dude take lots of pics lol,you mean a loom in the compartment by use steering wheel in the compartment to the right of it?
I stupidly took none whilst I was doing it, oops.
Behind your wheel, that big plastic bit lol.. Take the bottom bit off it's 3 screws, have a look in there. It should just be a a white plug hanging.
Okay cool,will check it out.if there is a plug hanging there is that a good thing.and if there isn't is it game over lol
If there's a plug, it's a 10 minute job (y)
If there isn't, it isn't game over as was my case. Depends how much patience you have lol
Oh so just hope there is a plug hanging there waitng,is there any chance of this happening lol
Not sure, it depends on the model I think. You have the 2.0 Multijet dont you? I know for a fact the 1.9 multijets dont have it prewired lol. ECU is ready to accept it regardless i believe.
Just have a look when you can, it's a quick job to check (y)
